D1200 stumbling out of Idle - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-25-2007, 09:44 AM   #1 (permalink)
Favourite Bike: 1996 Daytona 1200
Other Motorcycle: 2001 Trunderbird
Extra Motorcycle: 1999 Bandit 1200S
Question D1200 stumbling out of Idle
Trying to sort out a recently aquired 96 Daytona 1200. The bike oringally had clogged
jets and would not run more than 2 miles before stopping. Carbs were found to have rust from the tank clogging the jets. Carbs cleaned, tank flushed, inline fuel filters installed.
Can ride the bike, but there is a very noticable stumble or stalling from 1500-2000 rpm, which makes starting from a stop a real challenge. Above 2000rpm the bike takes off. Im looking at a new air filter, carb rubbers, and taking the carbs off again for another cleaning. Would cyncing the carbs help? Im at a loss.
Thanks
PAthunderbird
pathunderbird is offline   Reply With Quote
Old 09-29-2007, 07:50 AM   #2 (permalink)
Favourite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
pilot circuit still clogged
I am very sure that the pilot circuit is still clogged. after the rust did you use Kreem in the tank if not, if there is any tank rusting you will have problems from now on. you really need to detail strip the carbs. and clean the pilot circuit carefully, go to the welding shop and get a torch tip cleaner for the small holes and lots of cleaner and compressed air, take your time and really clean everything from both ends, flush with cleaner blow out repeat several times in both directions. this includes all the small holes in the emulsion tubes etc. also sometimes after a rust problem the needle, emulsion tube,and main get worn and cause problems.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 09-29-2007, 07:52 AM   #3 (permalink)
uzidzit's Avatar
Ps always sync the carbs
always sync the carbs after any work! and do at every 1500mi as reg maintenance.
Old 10-01-2007, 09:46 PM   #4 (permalink)
Newbie
Did you check the coils? the 1200 daytona is notorious for bad coils,I thought I had carb problems also at idle to 3000 rpm. but it was the coils.
Tea burner is offline   Reply With Quote
Sorting out my 96 d1200 pathunderbird Daytona Deliberations 3 09-23-2007 01:29 PM
Just bought a 96 d1200 pathunderbird Daytona Deliberations 5 09-15-2007 04:31 AM
D1200 seat won't come off Turin Daytona Deliberations 2 08-23-2006 10:40 PM
Sucking sound solves stumbling situation R100Pilot Speed Triple Forum 13 07-31-2006 09:06 PM
mounting clip ons above yoke on d1200 johnnycactus Daytona Deliberations 3 03-22-2006 03:23 AM
