Decel shimmy - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-20-2007, 11:17 AM   #1 (permalink)
Decel shimmy
I am getting a decel shimmy at about 40mph on a '02 triumph 17k with fairly new avon azaro..balanced ok,air ok....just got this bike about 3 weeks ago and seemed ok on my first outing of about 2 hrs, then last weekend i did a 4 day trip in the mtns and notice this shimmy when i did a hands off decel. I did adjust the chain before i left on the trip, my first chain adjustment since my dirt bike days( coming off of 3 shaft drive bikes).....any thoughts
tobyone is offline   Reply With Quote
Old 09-24-2007, 04:05 PM   #2 (permalink)
Favourite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
get the front end off the ground
swing the fork lock to lock and see if there is any bumpy feeling (worn steering head bearings) and push and pull on the forks front to back if there is any play and the above did not appear grease and adjust the preload on the steering head bearings.
at 17,000 it is probably about time.
these are the first places to look.
also loosen all the clamps from the wheel up and and allow all the parts to realign it is easy to pick up alittle tweak, hard to really bend anything without a crash.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 09-24-2007, 09:38 PM   #3 (permalink)
Favourite Bike: 03 tbs
I had a similar shimmy on my TBS after installing a new set of Avon storms. I thought it was the steering head bearings but the dealer installed a new front tire and the shimmy is gone.
super 3 is offline   Reply With Quote
shimmy tobyone Trophy 17 07-07-2008 02:56 PM
Front wheel shimmy cm08 Sprint Forum 11 01-16-2007 08:14 AM
Shimmy in Front wheel - Tried everything aleka Twins Technical Talk 10 10-03-2006 07:36 PM
Tach needle shimmy at 5k? d2mini Twins Talk 7 03-21-2006 09:04 AM
new tire shimmy dunringil Hinckley Classic Triples 9 01-29-2004 06:06 PM
