running problems. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-15-2007, 06:26 PM   #1 (permalink)
Other Motorcycle: xjr 1300 sp
Extra Motorcycle: thruxton 04
Smile jetting problems Please help meeeeeeeee.
hello
I have a 04 thruxton,it has tor pipes air box standard,(next job)
bike supposed 7000 miles,
starts terrible,runs ok when warm,
carb jets are 122.5 and 40,
I have been given advice to use 140, 42.
on inlet where vacume gauge can be fitted should ther be a pipe with one way thingy inside
also I see all the air pump and the valve type things have been capped off.
love me bike to bits please, someone help,
would like pics of carb mixture screw,
sorry if this is a familiar old story, but new to triumphs...
my other bitch is a xjr1300sp.mmmmBut no where near as much fun as the thruxton.
renny is offline   Reply With Quote
Old 09-19-2007, 03:15 PM   #2 (permalink)
Favourite Bike: 04 thrux blk(sold)
Gohm's Avatar
Other Motorcycle: 06 klr 650 grn
140 42 would be what you may need once you remove the airbox. Depending on your enviroment factors, I wouldn't suggest more than 115 for mains, 40 pilot with airbox & tors. The mix screws are underneath the carb, in the front. Should be under a metal cap. "D" screws inside will allow you to adjust. Easy to do as is, however I'd suggest pulling your carb if you are able so you can visually see what you are doing the first time. Also a good time to upgrade the carb screws. Starting issue could be all kinds of things. Here's a list of some things:
1. using choke correctly/no throttle when starting
2. check plugs
3. air leak at carbs or ehaust
4. mixture setting- a rich mixture can improve as engine warms up
5. idle setting
6. balance carbs
7. clogged/dirty air filter
Give us some more detail on exactly what you mean by "starts terrible" and post some pics of the vacuum gauge fitting and the sir injector fittings as these could be causing problems too.
Be a "weekend warrior" 7 days a week, 365 days a year!
My Photo Album
"A wink is as good as a nod to a blind bat" - MP
Gohm is offline   Reply With Quote
TT600 running problems from cold? Mr OCD Triumph SuperSports 4 11-08-2007 08:51 AM
bonnie running problems noiseyneil Twins Technical Talk 11 01-17-2007 03:45 PM
Tiger 885 Running problems Tiger Workshop (archive) 3 07-25-2005 09:03 PM
Running problems - advice please? fatboy686 Sprint Forum 7 06-06-2005 08:22 AM
Trophy Starting and Running Problems mnmrosen Trophy 10 05-30-2005 10:53 AM
