Tacho problem - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds! SportbikeTrackGear
Old 12-10-2004, 01:46 PM   #1 (permalink)
:???: Have a problem with the tacho on my 2000 Thunderbird - no reading, i.e. completely dead.
Have checked the wiring continuity, to igniter, to ground and to 12V ignition circuit, all fine. Swapped tacho with working unit, still needle plays dead. Could this be an igniter fault ? Bike is running fine, so other igniter circuits are OK.
Would be grateful for any ideas.
Tacho Lainer Twins Technical Talk 1 08-19-2007 10:43 PM
Tacho help IPAULR Speed Triple Forum 2 07-04-2007 03:18 PM
Problem: How to remove the Drive Pinion in the tacho gearbox? madd0g Classic, Vintage & Veteran 1 11-04-2006 06:52 AM
Tacho Problem... jimmyj900 Hinckley Classic Triples 0 12-13-2005 12:37 PM
Tacho problem Unklian Hinckley Classic Triples 2 11-18-2005 08:25 AM
