Allstate
AdvanstarMotorcycleShowsMotorcycle.com Classifieds!TriumphPerformanceUSASoupy's PerformanceSportbikeTrackGearMotorcycle.com Annitori Distributing
JardineProducts.com
Old 06-16-2007   #1 (permalink)
Favourite Bike: 2002 Sprint ST
deller4210's Avatar
2002 Triumph Sprint ST, rear wheel. Is it normal to have a little play in the rear wheel when rocking it back and forth with your hands located at the top and bottom of the wheel. There is no play if you grab the tire from the front and back and rock it back and forth but only when grabbing it at the top and bottom. I have checked the pinch bolt for the rear hub and it is tight. Also the torque on the wheel nut and axel nut are good. Normal, or not normal? That is the question. Thanks! :???:
deller4210 is offline   Reply With Quote
Old 07-11-2007   #2 (permalink)
Favourite Bike: 94 Mod 1200 Trophy 4
Other Motorcycle: 92 Mod Daytona 1000
Extra Motorcycle: 06 MV 910s Brutale
Hi, what you have described here is normal play , being old school I replaced all the bearings in mine when I first noticed it.. Ended up exactly the same after having done the job. I did some research & found that this is built in & normal due earlier bearing failures that didn't have enough tollerance :hammer: The play you can feel comes from the RH side hub needle roller bearing & from memory I believe Triumph gave it a tollerance of .6mm :wink: Hope this helps alleviate any concerns you have... Sweenz
Sweenz is offline   Reply With Quote
Old 07-16-2007   #3 (permalink)
deller4210's Avatar
Smile Rear wheel play on 02 ST
Sweenz, the play I had was worse than what I had posted. It was sever enough that I could feel and hear a clunking sound and it was a lot more than .6 mm. I removed the rear wheel and hub assemblies and rocked the swing arm back and forth with the same results. The swing arm would move side to side 1/4 inch as measured from the end. I could see the movement on the left side of the swing arm as I worked the thing back and forth. I replaced and lubricated the bearings and spacers, re-torqued the swing arm bolt and the play is now gone. However, there is still a very slight amount of movement, which I now believe is the .6 mm you are referring to, and I was wondering about it. Thanks for the info!
2002 Sprint ST rear wheel play deller4210 Sprint Forum 1 06-16-2007 12:40 AM
05/06 Sprint rear wheel removal bz919 Sprint Forum 1 07-15-2006 05:36 PM
Spinning the rear wheel on Sprint johnshumpert Sprint Forum 12 07-07-2006 04:11 PM
Help.. Rear Wheel Problems .. please advise 02 Sprint ST justducki Sprint Forum 4 05-18-2006 05:09 PM
Rear wheel nut size, 02 Sprint RS sjestory Sprint Forum 3 01-18-2006 12:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
