Help - increased handlebar & seat vibration - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Ontario TourismHonda Powersports
Old 05-31-2007, 01:19 AM   #1 (permalink)
extera1
After taking my 06 Speedie in for simple servicing (oil change, etc.) and having a new fuel tank installed, I noticed a significant increase in h-b abd seat vibration from the engine, particularly in 3400 4400 rpm range.
At first I thought I was crazy because none of the servicing done would have seemed to have any impact on engine vibration. But I'm convinced the vibration is not a figment of my imagination cause I'm tingling after a ride the way I used to many years ago after sitting too long on an old 250cc Yammie.
Any thoughts as to what the problem might be??? :???:
Old 05-31-2007, 01:32 AM   #2 (permalink)
Favourite Bike: 1998 Thubderbird Sport
idahotb's Avatar
Other Motorcycle: 1996 Sprint
Extra Motorcycle: 1997 T595 Daytona
Based only on the history my first guess would be a from engine stuttering from a interupted fuel supply. A partially kinked fuel line, or a non-vertical tip-over valve could be causing a slight fuel starvation, leading to an engine miss and increased vibration.
Just a guess. Hope you get it sorted out soon!
Speed is good. It is way better to be shot out of a cannon, than squeezed out of a tube. That is why God made motorcyles.
My album
idahotb is offline   Reply With Quote
Old 05-31-2007, 06:42 AM   #3 (permalink)
Bad gas?
Jhumphrey is offline   Reply With Quote
Old 06-01-2007, 12:10 AM   #4 (permalink)
Favourite Bike: 1967 triumph T120R old sc
el_nino3's Avatar
I'm going to add my 3 cents worth in hear..... being a tank was changed u might want to check fuel filter's tank might have not been flushed and it don't take much to cause problems i like to use the clear in line filters then u can see whats coming out the tank ...the tank might have been made on a Monday (workers hung over from weekend) or made on a Friday (workers in a hurry to get the HE-- OUT of there) ........................ good luck :???:
golf is the only thing in this world that can ruin a nice walk in the country......
el_nino3 is offline   Reply With Quote
Old 06-01-2007, 03:43 AM   #5 (permalink)
Favourite Bike: My '00 Sprint RS
kludge's Avatar
The tech probably displaced a rubber mount of some sort while replacing the tank.
My other ride is 28m2 of nylon
kludge is offline   Reply With Quote
handlebar vibration itcha Twins Technical Talk 7 01-03-2008 02:34 AM
Handlebar Vibration rickster Daytona Deliberations 13 08-03-2007 11:15 AM
handlebar vibration Bigman Twins Technical Talk 6 06-10-2007 03:06 PM
Help - Increased handlebar & seat vibration! extera1 Twins Technical Talk 3 05-31-2007 03:29 PM
Handlebar Vibration? 00wabbit Hinckley Classic Triples 2 09-09-2004 02:37 PM
