Is my front tire going to fall off?! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-29-2007, 02:01 AM   #1 (permalink)
BrianKal
Own an '06 Bonneville T100 with about 5,600 miles on it that has recently developed something of a intermittent grinding noise on the front end (left side).
Considered maybe some grit had worked its way into the bearings, or the dreaded warped rotor problem that I've read about but no hot spots on the rotor, no deep groves, no discoloration. Plus, it seems to me that both of those issues would cause a constant sound.
This sound seems to come and go at will, unrelated to speed, gear, turn direction, etc. The only consistent thing is that the slightest touch of the front break will silence the noise. Is this a brake pad issue? I seem to recall that they'll grind when they're going out on you.
One more clue: I had the the speedo cable work its way loose on me a couple of weeks back. Speedo drive problem?
What's my first step to get this figured out? Thanks in advance for any assistance.
[ This message was edited by: BrianKal on 2007-05-29 20:32 ]
Old 05-31-2007, 04:09 PM   #2 (permalink)
BrianKal
Or am I just so far off base that none of you are even going to bother responding?
Old 05-31-2007, 09:55 PM   #3 (permalink)
Sorry, but you've got a question I can't answer. Wish I could help, but I just don't know...
Cheers, good luck,
-Kit
Old 05-31-2007, 10:53 PM   #4 (permalink)
Favourite Bike: 1995 S3
trypcil's Avatar
Other Motorcycle: 1995 Sprint (cal) WC only
Waaaaay back I remember that the oem pads didn't last very long on my S3, take a look and see how much pad you have left - they may be nearly done. :razz:
http://www.triumphrat.net/photogalle...m794/album346/
The owl of Minerva spreads its wings only with
the falling of the dusk.” - G.W.F. Hegel, Philosophy of Right (1820), "Preface".
trypcil is offline   Reply With Quote
Old 06-01-2007, 01:03 AM   #5 (permalink)
Favourite Bike: 05 Black Speedmaster
Grinding and speedo cable problem at the same time ? Pull your front wheel and remove and inspect the speedo drive components before particles cause futher problems.
Old 06-01-2007, 12:27 PM   #6 (permalink)
Pull the caliper off and look at the pads...sounds like a brake problem if it goes away with a slight application of the brakes.
Ditch the OEM pads.
Good Night Austin Texas, wherever you are...
twstm is offline   Reply With Quote
Old 06-01-2007, 04:45 PM   #7 (permalink)
Favourite Bike: My '00 Sprint RS
kludge's Avatar
Sounds to me like the brake pads aren't pulling back properly but are dragging slightly. I would clean the caliper thoroughly, make sure the pistons are clean. If your caliper is the type with sliding pins, make sure to clean those and relube with the correct high-temp grease. Of course this is the perfect time to replace the pads if they are worn.
My other ride is 28m2 of nylon
kludge is offline   Reply With Quote
Old 06-01-2007, 05:03 PM   #8 (permalink)
BrianKal
Yup. You're all 100% correct. Broke down and took her by the dealership today. Front brake pads on the way out after only 5600 short miles (apparently my right hand is a bit stronger than my right leg as the rear pads are fine). Triumph dealer here in Tucson kind enough to diagnose the problem free of charge and I was lucky enough to pick up the last set of pads in stock. Now just waiting for my Haynes manual to get shipped so I can use my front brakes again! Though I don't imagine it's any different than the pads I once changed on an old '77 Cadillac I owned. Thanks for all the help. Peace.
new front tire..... ricster Sprint Forum 14 10-23-2007 10:27 AM
new front tire cfbpe Twins Technical Talk 7 07-23-2007 04:27 AM
New front tire Hornblower The Rocket Science Forum 3 07-18-2007 09:25 AM
Do I need a new front tire? 6485 Speed Triple Forum 18 03-12-2007 12:26 PM
What should I do about my front tire? kodos Triumph SuperSports 8 08-01-2006 08:39 PM
