On 2007-06-19 13:43, Eggman wrote:
Concerning the tappet blocks...................different people have different ideas on what comes w/ what when buying used parts. It would be nice, however. What makes an "R" tappet an "R" tappet?
'R' tappets have a larger radius than the standard ones. IIRC it's 1.50" vs. 1.25", or is it 1.25" vs. 1.00"?
The larger radius reduces wear on the cam flanks if you are running something like the E3134 cams.
If you buy a new cylinder it will not come with tappet blocks. If you buy a used one it will, since they are a chore to remove. Most people won't bother.
As to your original question, you can fit a unit 650 cylinder to pre-unit cases. Morgo made a 750 kit for the unit engine and 9-bolt head.
[ This message was edited by: kludge on 2007-06-21 02:46 ]
