Air Leak in Valve Stem - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGearOntario TourismMotorcycle.comMotorcycle.com Classifieds!
Old 05-24-2007, 04:16 PM   #1 (permalink)
Fed
After adding in a small amount of air to my rear Metzler tire (for what was a small leak) a significant leak erupted out of the valve stem itself. Rather then lose all of the air in the tire, I screwed the valve stem cover back on and that seems to have stopped the leak for now. Question is, do I need a new tire or is this an easy valve stem fix?
Hopefully I've been able to describe the problem properly, I'm an accountant not a mechanic, but for now I've been able to steer away from the term "doo-hickey" ;-)
Fed is offline   Reply With Quote
Old 05-24-2007, 07:33 PM   #2 (permalink)
There's valves in them thar stems! :-D
(Sorry, feeling a little wacky today!)
Any auto store should have valve stem wrenches for sale. It sounds like your valve is loose inside the stem. It could also be a defective valve, in which case it would need replacement. The same auto shop should have valves as well, probably next to the stem wrenches.
It could be something worse that would require replacement of the tire, but it sounds like it's probably just a loose or broken valve. (Of course, do keep in mind that I'm an IT guy, not a mechanic... :wink: )
Cheers,
-Kit
Old 05-24-2007, 07:58 PM   #3 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
The valve stem is not connected to the tire., it is part of the innertube.
If at worst the valve is defective in some way, the worst would be that you would have to replace the innertube, not the tire.
Try replacing the valve first and see if that fixes it.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 05-24-2007, 10:03 PM   #4 (permalink)
Good point, Bob. I always forget that some tires still have tubes!
(And now that I think about it, I guess the valve stem isn't part of the tire on a tubeless setup either...)
Cheers,
-Kit
valve stem nut Programr Twins Technical Talk 4 12-24-2006 04:26 PM
Valve stem leaking t100bob Twins Technical Talk 4 10-08-2006 06:31 PM
valve stem replacement madmic Tiger Workshop (archive) 2 09-06-2006 07:59 AM
Right angle valve stem adapter martingilly Hinckley Classic Triples 4 08-27-2006 11:18 PM
Metal valve stem caps j98sprint Maintenance & Workshop Talk 0 05-03-2002 10:08 AM
