Bar Riser Bolts: 8.8 or A2-70? - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGear
Old 05-23-2007, 05:16 AM   #1 (permalink)
Favourite Bike: '02 T'Bird 900
TonyD's Avatar
I recently bought some bar risers, but the 8.8 grade bolts supplied are too long. I have some stainless A2 bolts that are of the right dimensions, but I have read that stainless steel bolts should not be used for high tensile applications (because they snap under stress rather than bend). The stock Triumph bolts already holding the clamp look to be stainless, but are not stamped with any indication of grade.
Could anyone advise if stainless A2-70 are suitable for use with bar clamps/risers (the torque setting would be 22Nm)?
TonyD is offline   Reply With Quote
Old 05-23-2007, 11:31 AM   #2 (permalink)
The short answer is that if the original fasteners are stainless, you're probably fine.
A slightly longer answer is that A2-70 has somewhere between 2/3-3/4 of the strength of 8.8 steel. Grade 8.8 M10 bolts will handle 45Nm, so A2-70 should be just fine w/ 22Nm if you're talking about replacing the 2 large bolts that hold the bar clamp to the top triple. If you're talking about the 4 M8 screws that hold the bar clamp together, I suspect a typo in the Haynes manual. I would torque those to 16Nm or so for stainless. (25Nm is the limit for 8.8 steel or A2-80 stainless.) Use some blue thread locker if you're worried that they won't be tight enough, or spring for some A2-80 (or A4-80) stainless bolts.
HTH,
-Kit
Old 05-23-2007, 04:50 PM   #3 (permalink)
TonyD's Avatar
Thanks, Kit. The screws in question are indeed the four M8s holding the bar clamp together. On closer inspection the originals are chrome, so may be carbon steel rather than stainless.
Haynes does specify 22Nm, but then so does the Triumph Service manual. I think I will look at sourcing higher grade screws in light of what you say about the maximum torque for 8.8/A2. I see that some US suppliers refer to 18.8 stainless, although that is not a grade I have yet found amongst UK suppliers.
Old 05-23-2007, 05:46 PM   #4 (permalink)
18-8 is almost the same as A2-70 (18-8 is SAE, A2-70 is metric). Here's a helpful link.
Cheers,
-Kit
The Great Bar Riser Question super 3 Speed Triple Forum 7 09-05-2007 10:32 PM
Triumph fat bar riser height NinjaRAT Speed Triple Forum 9 08-24-2007 03:47 PM
Bar Riser deal Stlakid Sprint Forum 3 06-04-2007 02:45 AM
Jenks Bolts LED's and Bar riser doctorjay Twins Technical Talk 4 03-05-2007 10:24 AM
renthal handle bar riser? Agkistrodon Speed Triple Forum 0 07-27-2005 01:46 AM
