From what i read once it sounded like you MUST ground the plug wire straps. Can't recall why, but i do recall it being necessary to insure they don't go bad. I see no reason to risk it in case that is true, so i made sure to ground them. I attached them with the bolts from the AI valve i removed if i recall correctly, tho it's been a while. Plug gap should be .031 to .035, or .8 to .9 mm.
