Neutral Light Intermittent Failure. - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comNew BonnevilleOntario Tourism
Old 05-17-2007, 06:14 PM   #1 (permalink)
Favourite Bike: Depends on mood
Ballacraine's Avatar
Other Motorcycle: Brit, Italian & American
My newly purchased T309 6 Speeder seems to have a minor fault, in that the neutral light ceases to function when the motor is warm.
When it is cold it works fine again.
I am returning it to the dealer for rectification, when i can find a mutually convenient 'window.'
I thought I would ask though, if anyone has come across this symptom and what the cause was?
Off the topof my head I am guessing faulty neutral switch.
Anyone any ideas, please?
TIA
Nige.
[ This message was edited by: Ballacraine on 2007-05-17 16:14 ]
In faecorum semper solum profundum variat.
(Always in the s**t it is only the depth that varies)
Nige's Gallery
Ballacraine is offline   Reply With Quote
Old 05-17-2007, 07:09 PM   #2 (permalink)
It does sound like a bad sensor. Check this thread over in the T3 forum.
It's about a $30 part, & installation & removal appear to be quite simple if you don't want to leave it at the dealer.
Cheers,
-Kit
Old 05-17-2007, 07:30 PM   #3 (permalink)
Thanks for the link, Kit.
It seems according to Jetmech, if I just remove the washer from the sensor, I should be good to go!
:hammer:
Thanks again for the info.
Nige.
Nige's Gallery
Old 05-18-2007, 12:57 AM   #4 (permalink)
No prob, Nige. Good luck with it!
-Kit
Neutral Light failure Boss Speed Triple Forum 12 02-15-2008 10:21 PM
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 09:58 AM
01 Adventurer intermittent sprark failure! HELP! micky Maintenance & Workshop Talk 0 03-26-2006 10:42 AM
Intermittent neutral light jdumas54 Maintenance & Workshop Talk 3 05-21-2004 12:39 PM
Intermittent rear light fault JohnRimmer Daytona Deliberations 0 04-04-2004 03:00 PM
