Engine Fault Codes - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!Motorcycle.comNew BonnevilleHonda Powersports
Old 05-10-2007, 04:57 PM   #1 (permalink)
Does anyone know wheer I can find a listing of all the codes and what the y mean (02-04 Speed Triple)? I have a tuneboy and the diagnostics tool pulled the code but I have no idea if it is severe or if I should just clear the code....nearest dealer is 60 miles so I'm hoping to get info from here.
2003 S3
Skyking Bar Ends
Skyking Frame Sliders
Seat Cowl
Trident Stubby
Tuneboy
H4 headlights
Razorback_Fan is offline   Reply With Quote
Old 05-10-2007, 05:18 PM   #2 (permalink)
oldndumb's Avatar
The generic codes are the same for any manufacturer. The Triumph specific codes are in the Shop Manual. I don't have one for your bike.
Maybe if you repost and list the codes you are getting, someone will look them up for you.
Oldndumb
Caveat lector
Old 05-10-2007, 05:25 PM   #3 (permalink)
The code is P0463 Fuel Level Input Sensor shorted high........I'm wondering how to fix the problem...clear the code or take it to the stealer? Basically all it is doing is making the low fuel light come on at random.
2003 S3
Skyking Bar Ends
Seat Cowl
Trident Stubby
Tuneboy
H4 headlights
Old 05-10-2007, 05:38 PM   #4 (permalink)
Location: El Dorado, AR smack dab in the middle of nowhere
Shoot me a PM if you can't find it or if someone doesn't post a link as I printed it out earlier this week. Just can't remember from where it was or on which site.
Wouldn't you know I'd find it as soon as as I posted I couldn't find it? The code list is in the Knowledge Base on t595.net under Technical articles under the Maintenance section.
Anyway, as you said, it shows code P0463 as fuel sensor circuit high input. Sorry, don't know exactly what that means. Might speak to your dealer's service mgr. and ask if it's serious or just more of a nuisance issue. He may spill the beans and tell you how to fix it.
[ This message was edited by: soonerfan85 on 2007-05-10 15:49 ]
I will be strong and courageous, I will not be terrified, or discouraged; for the Lord my God is with me wherever I go. Joshua 1:9
soonerfan85 is offline   Reply With Quote
Old 05-10-2007, 07:30 PM   #5 (permalink)
Yeap I'll shot him a ring tomorrow...Thanks for looking anyway.
2003 S3
Skyking Bar Ends
Seat Cowl
Trident Stubby
Tuneboy
H4 headlights
Old 05-10-2007, 11:12 PM   #6 (permalink)
oldndumb's Avatar
Thats one of the generic codes. On a Triumph it indicates a fault between two ECM pins and the correspoding contacts on the fuel level sensor. I don't have a schematic for your bike so I don't have the pin numbers. Don't know how hard it to get to them, but sometimes all it takes is unplugging and replugging the connectors (pwr off).
Oldndumb
Caveat lector
Old 05-11-2007, 03:55 PM   #7 (permalink)
Favourite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
here is the full listing of codes:
http://www.t595.net/kb/technical/article.asp?id=58
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
chefjpd is offline   Reply With Quote
Old 05-12-2007, 09:53 AM   #8 (permalink)
DEcosse's Avatar
You can find a complete listing of the error codes in a post by me in this thread
I dont know why it says it doesn't in the table which is taken directly from the manual, but as you are experiencing it most certainly WILL illuminate the MIL.
It is very likely to be the fuel sender itself. Could also be a bad/intermittant connection of the plug.
Normal resistance reading for the sender is 13 to 91 ohms.
Go to your local Radio Shack & get a 47 ohm resistor & connect it across the harness side of the connector plug temporarily (leave tank sensor disconnected) and see if that eleminates your problem.
If it does, replace your tank sender.
[ This message was edited by: DEcosse on 2007-05-12 07:53 ]
T'Rat.net BOTM November 2009
Engine Fault Codes Razorback_Fan Speed Triple Forum 3 05-10-2007 09:20 PM
Engine Management System fault? matdav Sprint Forum 8 10-09-2006 08:59 PM
Are fault codes same for 2001 and 2002 Sprints? kpp80202 Sprint Forum 1 07-13-2006 02:21 PM
Engine Light - ECU fault?? JTBS Sprint Forum 6 05-15-2005 12:38 PM
Engine Fault Light Maintenance & Workshop Talk 8 06-27-2004 08:39 PM
