wot size is the Front Sprocket Nut - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearHonda PowersportsNew BonnevilleMotorcycle.com Classifieds!
Old 05-07-2007, 01:31 PM   #1 (permalink)
on a Scrambler ?
i need to remove it so i can get to the gearchange Shaft and Repalce it
Also when i took the Clutch cover off to cut the bent shaft off to make removal easier a Wavy Washer thing fell out whilst iwern't looking ??? where the hell does that go
ta
pugwash is offline   Reply With Quote
Old 05-15-2007, 05:13 AM   #2 (permalink)
A 36 mm socket is what you need for the big nut. An assistant is handy as you need to put it in gear and hold the back brake on to get it undone. Yes it is tight, breaker bar and piece of water pipe tight.
Ahh, yes the ol' wavy washer trick that's the third time this week (in best Don Adams voice) it goes on the starter idler gear, I had one of them on the floor after I changed clutch springs, it ran OK without it but I didn't like it so I sprung for another primary gasket and bottle of oil.
Post a pic of your bandit.
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Socket size for front sprocket nut? awegs955i Daytona Deliberations 2 08-01-2007 06:21 PM
Front Sprocket Nut Blackjack Twins Technical Talk 9 12-18-2006 01:25 PM
Front sprocket nut size??? TheToeCutter Sprint Forum 13 09-16-2006 01:34 PM
Front Sprocket Nut Size 2001f4s Speed Triple Forum 6 10-04-2005 11:24 PM
Nut size of the Bonneville front Sprocket? s22k77 Twins Talk 6 06-27-2005 08:15 AM
