Chain Lube... - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda Powersports SportbikeTrackGear
Old 05-01-2007, 01:40 PM   #1 (permalink)
Well, I'm kind of a dumb ass and while lubing my chain I got lube all over my back tire. In retrospect I should have held a piece of paper or something between my chain and back tire but you know what they say, hind sight is 20/20. so that being said I was wondering if anyone out there has any good tips on how to get the lube off my tire.
\Don't take any guff from these swine.
Blacklion50 is offline   Reply With Quote
Old 05-01-2007, 03:47 PM   #2 (permalink)
Soap, water, & elbow grease will do it. So will asphalt, as long as you're real careful. :-D
(Yes, the paper is a good idea!)
Cheers,
-Kit
Old 05-01-2007, 04:48 PM   #3 (permalink)
Yeah, I thought about the asphalt thing but it's kinda near the edges and leaning my bike that far over with anything with "lube" in the title stuck to it seems like kind of a bad idea... but I'll work on the soap and water thing
Old 05-02-2007, 05:41 PM   #4 (permalink)
Favourite Bike: 05 Sprint
mglemans86's Avatar
Other Motorcycle: 72 Norton Commando
Extra Motorcycle: 86 MG Lemans
I just used Gunk engine cleaned on a rag to clean chain wax off my rims and it worked great. It's water soluable to so you can rinse residue off with water
"Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself."
-Mark Twain
mglemans86 is offline   Reply With Quote
Old 05-03-2007, 05:17 PM   #5 (permalink)
I used the gunk today and the results were awesome, just sprayed it on my tire, let it sit for 10 min. and rinsed it with the hose and all the lube is gone, thanks for the tip.
chain lube,what do you use? AH-1 Speed Triple Forum 33 06-29-2008 08:16 PM
Chain lube? MickMaguire Maintenance & Workshop Talk 41 03-25-2007 02:30 PM
Chain lube rays323929 Twins Talk 3 05-05-2006 10:07 PM
To Lube the chain or not to Lube...that is the Question Clanrickarde Twins Talk 27 02-25-2006 09:37 AM
Chain Wax vs. Chain Lube Celeste Twins Talk 4 09-01-2005 01:14 AM
