'95 Speed Triple Overheat light - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comOntario TourismSportbikeTrackGear
Old 04-30-2007, 06:20 PM   #1 (permalink)
DPFan
Hope someone may be able to help. The overheat light on my '95 Speed Triple keeps coming on when the bike is fully warm just before the fan cuts in. I've checked the T/stat, replaced the cylinder head temp sensor and checked cooling system for blockages (none found) but no joy. Have owned the bike from new and apart from a hose change under warranty for a weep it's had no problems till now. I've seen another post with the same problem from a member in the US, is there a fix out there??
Old 05-07-2007, 07:00 PM   #2 (permalink)
MacTheKnife
I have a 95 black triple as well and did have some problems that I posted so maybe you mean me. I chased the problem for a while but simply replaced the themostat and drained and filled. I can't remember for sure, but I think I even replaced the Fan switch and that that was the problem as I had had that one before. Sorry to be so vague and all. It shocked the heck out of me to even see anyone with this bike. The triumph dealer here told me that my bike didn't even exist until I offered to ride it up his backside. Let me know what you finally figure out. Good luck
Old 05-07-2007, 09:52 PM   #3 (permalink)
Favourite Bike: 1995 Triumph Speed Triple
tealetm's Avatar
Other Motorcycle: 1972 Trident T150V
Hmmm... I've heard of a few people having this problem- but haven't heard a resolution.
Speaking of cooling systems though- my fan seems to be coming on more than it used to. Makes me wonder...
Anyone fit a temp. gauge on a T3 before?
Travis
Albany, NY
tealetm is online now   Reply With Quote
Old 05-07-2007, 09:59 PM   #4 (permalink)
Some T3s had gauges instead of lights. My Trident has a gauge. I have a spare set of working gauges with broken plastic; we could probably work something out if you want to build a frankencluster.
Cheers,
-Kit
Street triple screen on Speed triple Buster Speed Triple Forum 49 10-22-2009 02:34 AM
95 speed triple's overheat light coming on crabs Speed Triple Forum 12 10-27-2008 08:05 AM
Speed Triple Tach/Trouble Light Wiring Help kuhlka Speed Triple Forum 6 10-29-2006 07:31 PM
FS: '04 Speed Triple SE, 'touring Triple', Seattle CaptainFlake Speed Triple Forum 8 09-21-2006 09:15 PM
Overheat light comes on with flashers Fozzy Hinckley Classic Triples 1 09-14-2004 05:45 PM
