94'ST, Chain & Sprocket replacement... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-28-2007, 04:07 AM   #1 (permalink)
HS
It's time for a change of Chain & Sprocket on the Speed triple. Normally, with previous bikes, I have always purchased the C&S myself, and then had a local dealer do the work. This would usually cost no more than about £25, so it was not worth the trouble for me to get my hands dirty, especially seeing as a chain tool is about £45.
However, having ordered the C&S for the Speed Triple, I phoned around for a price to get them renewed (aware that it is a little more work on the ST).
The quotes are all coming back in the £100 labour only price range.
So, I guess it's time to get my hands dirty after all.
I have use of a Chain tool, and have the relevant seals, gaskets and filter on order. I have read up on the procedure (Haynes Manual).
I have just one question remaining....
Are there any 'little surprises' awaiting me?, or does anybody have any hints/tips? that they have discovered when doing the same job, that'll make life that little bit easier?.
Any advice regarding this topic would be welcomed.
[ This message was edited by: HS on 2007-04-28 02:09 ]
What you see, depends on where you stand.
HS is offline   Reply With Quote
Old 04-28-2007, 06:22 AM   #2 (permalink)
Favourite Bike: Triumph
johnyC's Avatar
HS,
Your first surprise will be the puddle of oil you get when you pull off the sprocket cover, especially if you only have a sidestand. When I did the job on my tbs I drained the oil first, put new oil & filter in when the job was done.
Before you get that far make sure you have a 36mm socket, not supplied with most socket sets. I had to go out to Halfords and buy one.
Get the sprocket nut loose before you take the old chain off. I put the bike in 1st gear and got someone to stand on the rear brake pedal whilst I undid the nut.
I don't have a chain tool, so to remove the old chain I grind the pins (small disc in battery drill) down to the plate on one link then prise the plate off. I have the use of a riveting tool to put the new chain on, don't forget to install the 'O' rings before you press the new plate on!!
Nearly forgot, surprise no.2:
here's a thread from a while back that explains in the last paragraph of my post :-D
tbs chain length
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 04-28-2007, 11:30 AM   #3 (permalink)
HS
Cheers for the reply Johny, I'll make sure I have a bowl under the front sprocket cover. I guess I'll also be making a trip to Halfords for a socket too.
Old 04-29-2007, 03:26 AM   #4 (permalink)
Favourite Bike: Orange TBS,the fast color
Other Motorcycle: Can there be room for 2?
If you stand the bike upright you will probably get nothing more than a tablespoon or two of oil.
Yee-haaaaa!
Old 04-29-2007, 04:50 AM   #5 (permalink)
HS
It has a centre stand, so it will be upright. I'll still make sure I have abowl in place though. Belt and Braces.
Tips wanted for chain sprocket replacement and lube info stwanted Sprint Forum 8 03-11-2007 02:30 PM
rear wheel sprocket bolts replacement gatortiger Maintenance & Workshop Talk 8 10-23-2006 09:33 AM
Chain/sprocket replacement parts? T3 Sport / Touring Forum 13 08-11-2006 10:56 PM
Sprocket replacement question flashmc Twins Talk 6 06-03-2006 11:59 PM
Front sprocket replacement NinjaRAT Sprint Forum 8 09-25-2005 11:30 AM
