I put Progressives on my old KZ440. I had to pull both of the originals to do it. IIRC, I also needed a friend & a rubber mallet. (Mind you, this was after spending a couple days with some KY & a big c-clamp to get the proper bushings into the eyelets...) :razz:
Chain slack should not make any difference, & you're correct about needing to support the rear wheel. A wedge might make the difference between needing a friend & not.
HTH,
-Kit
