sprint rs won't start!! - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comNew BonnevilleOntario TourismSportbikeTrackGear
Old 04-25-2007, 04:09 AM   #1 (permalink)
pointer
strange problem developed over the past couple of weeks, occasionally when I hit the starter all I'd get would be the sound of the relay under the seat clicking. I found that if I bounced the forks up and down it would normally / sometimes start after a while? loose connection on clutch lever switch possibly so I linked that out and once again sometimes it would start and sometimes it wouldn't. i checked out the 'clicking relay' and that also appeared to be clean and working correctly. intermittent faults aagghh! any ideas would be gratefully received..
Old 04-25-2007, 06:59 AM   #2 (permalink)
Sidestand switch is a poss.
Also alarm wiring plug under seat has a wire link in it that will stop the bike starting if it is not in place correctly.
9264 is offline   Reply With Quote
Old 04-28-2007, 02:23 AM   #3 (permalink)
Loose wire? Check the starter relay connectors and the thick one on top of the starter.
Check the battery terminals for a loose bolt. (With a poor connection there might be enough voltage to activate the ECM and relays but not enough amps to engage de starter)
Also check the battery fluid levels and gravity in each cell as bouncing the bike might just be redistributing fluid that collected on the left from leaning on the sidestand.
Otherwise there could be a loose/corroded connector somewhere (easy to check) or some damaged wire from twisting/rubbing between the frame and fork but that's unlikely.
As for the alarm plug looping wire, it forwards +12V to the start switch when no alarm is fitted.
AlexTiger is offline   Reply With Quote
Old 04-30-2007, 05:06 AM   #4 (permalink)
pointer
thanks to all for all the ideas........ i'll check them out one by one
So I can't start the Sprint shane Sprint Forum 12 07-02-2007 06:54 AM
Sprint won't start... katrider Maintenance & Workshop Talk 4 06-14-2007 10:15 PM
Sprint will not start??? Jaracer64 Sprint Forum 5 11-23-2006 06:36 AM
Sprint won't start, HELP! cricket1 Sprint Forum 6 05-17-2006 07:51 PM
HELP. SPRINT ST WONT START Maintenance & Workshop Talk 6 03-28-2004 03:29 AM
