Mixture screw adjustment - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-29-2006, 10:56 AM   #1 (permalink)
swgee
Just removed the baffle from my stock pipes on a 2002 bonnie. What would be a good start on the idle mixture screw. 2 or 3 turns out? Bike runs good except slight stumbling at initial roll on of throttle. Everything else (mains, pilots.. ) all stock.
Old 12-30-2006, 01:26 PM   #2 (permalink)
Favourite Bike: Depends on mood
Ballacraine's Avatar
Other Motorcycle: Brit, Italian & American
Sounds OK to me, but I don't know anything specific to your bike model.
As for the stumbling, I would check your cable adjustment.
It may be a little slack?
Nige.
In faecorum semper solum profundum variat.
(Always in the s**t it is only the depth that varies)
Nige's Gallery
Ballacraine is offline   Reply With Quote
Old 01-02-2007, 08:55 AM   #3 (permalink)
Whenever I adjust my mixture screw, I start it out around 3 turns and ride the bike to warm it up to normal temp. Then I set the rpm to 1000, take the screws in together at 1/4 turns. As you lean the mix, the RPM's wil rise. If the rpm's go above 1500, I reset them to 1000. You will get to a point where the rpm's will stop climbing. At that point i back them out 1/4 turn, set the rpm to 1000 and ride. I readjust them in winter and summer. Plugs always look great and never run into backfiring on a downshift.
AVMECH is offline   Reply With Quote
Old 01-03-2007, 12:15 PM   #4 (permalink)
swgee
Thanks for the help. 3 turns out seems to be the magic number right now. No hesitation or backfires. It may be just me but she seems to accelerate a tad better now than before.
Idle mixture screw Blacklion50 Maintenance & Workshop Talk 1 04-11-2007 11:02 AM
What does the mixture screw do? n578md Twins Technical Talk 7 08-12-2006 09:27 PM
Mixture Screw dave31grant Twins Talk 5 01-11-2006 10:37 PM
Idle mixture screw, in or out Lovechops Twins Talk 5 10-10-2005 01:27 PM
Mixture screw location? JonnyAstro Hinckley Classic Triples 2 08-18-2005 05:40 AM
