shim removal on T3 Sprint 900 (96) - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Ontario TourismSportbikeTrackGearMotorcycle.comHonda Powersports
Old 12-22-2006, 10:55 AM   #1 (permalink)
Heres a curious one. I decided to check valve clearances. 2 on the inlet side were out of tolerance and shims need replacing.
Borrowed tool 3880011 from my local dealer which allows the tappet to be locked in position when cam is rotated. This is correct tool according to the ws manual and has correct number etched on it. But it just does not fit/work at all. Looks to be for a completely different engine.
Anyone come across this before? I've pondered it for an hour trying it every which way and thinking 'it must be me' and what am I doing wrong - but I cant see it!! :???: I'm going to ask dealer later on today - but thought I'd ask here first...
illusionist
illusionist is offline   Reply With Quote
Old 12-22-2006, 01:30 PM   #2 (permalink)
As a follow up - the dealer now uses a tool that attaches to the cam cover fixing points as per other posts. Looks like the one they've lent me is a very early type. Plus I'm convinced its the wrong one - even though part numbers match up.
illusionist
Valve Shim Removal Tool? Wychall Hinckley Classic Triples 17 03-22-2011 04:58 PM
Valve Shim Removal Tool Tassie_Tiger Tiger Workshop (archive) 9 12-10-2007 09:55 AM
Valve Shim Removal Tool Bluetiger901 Maintenance & Workshop Talk 1 01-15-2007 01:34 PM
shim removal tool triumphtimes Sprint Forum 1 10-16-2005 12:32 PM
1996 sprint 900 starter motor clutch removal... RIDING_SCOTSMAN Sprint Forum 0 07-05-2005 11:05 AM
