Looking for custom size bolts - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsOntario TourismMotorcycle.com Classifieds!
Old 12-21-2006, 12:44 PM   #1 (permalink)
Looking for a good source for a custom bolt. I took off the hideous mirrors on my Scrambler and went with bar ends, however, the mirror held on the front brake reservior. I would need a short bolt - I think a M10x1.25 about 3/4 of an inch long - to replace it. Everything at the auto parts store is too long. Any suggestions would be helpful. Thanks
Not likely to die of natural causes
tri650 is offline   Reply With Quote
Old 12-21-2006, 01:00 PM   #2 (permalink)
Favourite Bike: My '03 America
agogel's Avatar
You can try here....
Chrome Bolt
Depending on where you are in Missouri....there are a couple of True Value/Ace hardware stores around St Louis that carry a good assortment of metric and chrome bolts, spacers etc.
Also here
[ This message was edited by: agogel on 2006-12-21 11:02 ]
Tony G
"If you don't get what you really want, it's your own fault"
agogel is offline   Reply With Quote
Old 12-21-2006, 01:21 PM   #3 (permalink)
kubihibi
get the correct tread size from the auto store. Length can ALWAYS be fixed, as long as the bolt is "too long." Grab yourself a nut that fits the bold also.
Here is what we are going to do. Have a dremel tool? A hack saw will work also. Measure twice, cut once! Figure out how long you need the bolt to be to fasten the part down, but not so long as it bottoms out. Thread on the nut to the point where the bottom of the nut is the max length you want the bolt to be. Start cutting. The bolt will protect the threads, and if you use the dremel you can clean it up nice afterwards too... but that isnt necessary.
Old 12-21-2006, 03:52 PM   #4 (permalink)
DEcosse's Avatar
http://www.fastenal.com/web/location...&zip=&state=MO
Are you sure it's 1.25 (fine) thread? I would have expected 1.5 might be for that location.
T'Rat.net BOTM November 2009
Old 12-21-2006, 04:25 PM   #5 (permalink)
Now you have me thinking I measured wrong. I took it to an Auto Zone where they have the various thread dimensions you can compare to - I guess I will check it again to make sure.
I have thought about just cutting a bolt, but I want to find a rounded top that will be less conspicious.
Old 12-21-2006, 04:36 PM   #6 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
Triumph used to use a black plastic plug for exactly that on the early daytonas and Trophys as the mirrors were mounted on the fairing and not the cylinders. Your dealer should be able to supply some (I bought some a few years back). Alternatively look on mcmaster.com for plastic plugs or bungs.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 12-21-2006, 07:26 PM   #7 (permalink)
Favourite Bike: 2002 RS
Stlakid's Avatar
Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
Part # 92095A410 @ McMaster-Carr
10mm x 1.5mm (thread pitch) x 20mm long Stainless Steel Button Head Cap Screws. You have to buy a pack which is 10 pcs. Price is $7.62 for the pack.
Just type the part # into the search and it will bring you to the page for it.
[ This message was edited by: Stlakid on 2006-12-21 17:28 ]
My Photo Album
Stlakid is offline   Reply With Quote
What size bolts - grab rail? BishRat Twins Technical Talk 2 11-29-2007 09:51 AM
Size of engine mount bolts wookie Speed Triple Forum 1 06-23-2007 12:59 PM
size for front forks pinch bolts for axle? tekmoe Speed Triple Forum 1 08-14-2006 11:36 AM
custom made seat bolts bonnevillebilly Twins Talk 2 06-13-2006 10:54 PM
Size of Fork Cap Bolts wenzel850 Twins Talk 3 03-10-2006 01:47 PM
