Logic of Drain Oil While Hot Escapes Me - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew BonnevilleSportbikeTrackGear
Old 12-18-2006, 04:35 PM   #1 (permalink)
Why is the "drain the oil while it is hot" always reccommended?
Seems to me that if you shut down the motor while it is hot, and then come back the next day and drain the oil, don't you get it all? Maybe a bit more is going to cling to the sides of a cold sump?
Is the difference really worth dealing with a hot plug, filter and risk of splashing hot oil on yourself?
Ivan
When an objection cannot be made formidable, there is some policy in trying to make it frightful; and to substitute the yell and the war-whoop, in the place of reason, argument, and good order.— Thomas Paine
TheLiveEye is offline   Reply With Quote
Old 12-18-2006, 04:49 PM   #2 (permalink)
tcb
The idea is that small particles of metal, etc. are in suspension for a short time and will come out with the oil, rather than settling down into various crevices in the crankcase. :-D
tcb is offline   Reply With Quote
Old 12-18-2006, 05:15 PM   #3 (permalink)
Plus when the oil is warm or hot it tends to be thinner so more oil is removed and it takes less time.
Spyke is offline   Reply With Quote
Old 12-18-2006, 05:40 PM   #4 (permalink)
kubihibi
Dont forget the motor industry, oil conglomerates, and medical industries are in cahoots!!!
Old 12-19-2006, 07:36 PM   #5 (permalink)
TCB is right...when you drain your oil after running the motor at operating tempeture, all the junk such as metal particles, soot, carbon and and any gas dilusion all gets blended together with the hot oil which helps get all the byproduct junk out of you engine. Besides, nothing is better for your complextion than a good ol'e splashing of used motor oil on your mug! :-D
Bigern
Life's too short to ride Jap bikes!
bigern2300 is offline   Reply With Quote
oil light after oil drain and refill 82triumph750 Classic, Vintage & Veteran 4 02-02-2008 02:47 AM
Thanks guys. Now How do I Drain Some Oil? meistro Twins Technical Talk 11 10-09-2006 09:19 PM
Oil Drain Plug Londonspride Twins Talk 4 09-09-2005 10:25 AM
Oil Drain Plug Londonspride Twins Talk 2 09-09-2005 12:29 AM
Oil Drain Plug Londonspride Twins Talk 0 09-08-2005 09:41 PM
