Plastic gas tank REPAIR ??? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-17-2006, 10:09 PM   #1 (permalink)
Does anyone know how to fix a leaking plastic gas tank, or did anyone ever repair one and HOW, with WHAT ???
All I find on the internet is repair kits for metal tanks...
Bluetiger901 is offline   Reply With Quote
Old 12-17-2006, 10:57 PM   #2 (permalink)
kubihibi
Drain, then you have a few options;
1) plastic weld
2) JB Weld
3) bubble gum, duct tape, and a tube sock
Old 12-18-2006, 10:03 PM   #3 (permalink)
:hammer:
Did anybody here ever use "JB Weld" ???
I have a leaking plastic tank on a 96 Tiger. The leak is where the fastner screw is on the right front lower side and this is where the fairing bolts on to ,or fastens on to the tank.
Old 12-18-2006, 11:22 PM   #4 (permalink)
kubihibi
Try it. Worst case is it wont work.
Old 12-19-2006, 12:34 AM   #5 (permalink)
Favourite Bike: 2008 1050 ST
rs_tt's Avatar
Other Motorcycle: 02 Sprint RS..sold
try this stuff plastex
rs_tt is offline   Reply With Quote
Old 12-19-2006, 01:59 PM   #6 (permalink)
DEcosse's Avatar
One of my vent tubes inside the tank was leaking - when tank was greater than 1/2 full it would drip out of the hose; the garage would be reeking in the morning! It must have been marginal from outset I think - I don't see how that could fail.
Anyway I drained & removed tank, & removed the pump assembly for access from there, as well as through the filler neck. Make sure tank is completely empty & free from any vapour.
Then I built up a few layers of JB Weld coating the tube (painted it on with a paint brush) letting it dry thoroughly between each coat.
It's been perfect since - no problems with the JBWeld deteriorating in the presence of gas.
I would use same approach for your situation - apply to the inside & build up a few layers - you might want to apply fairly thick over a larger area than just localized since it might be more of a stress point because of the mount. Scratch up the surface to give the initial weld a better 'key'. Since you're in the frozen North you might want to do this in a heated environment to allow for better curing. I actually used a hair dryer (don't laugh!) to help accelarate the curing process. After final layer, leave at least 24 hrs before re-installing & filling with gas.
You might also want to consider re-inforcing the outside at the mounting point with additional JBWeld.
[ This message was edited by: DEcosse on 2006-12-19 12:01 ]
T'Rat.net BOTM November 2009
Old 12-23-2006, 08:22 PM   #7 (permalink)
Someone has a Sprint gas tank in black for sale her for $50
i bet you can't fix your own tank for that $$
The ad said in good shape but some scratches
mikey
mikey is offline   Reply With Quote
Black plastic tank - Question? Tricks Speed Triple Forum 9 10-31-2006 07:48 AM
gas tank repair -- seem fair? johnnypence Classic, Vintage & Veteran 17 08-14-2006 07:32 AM
955i Plastic tank Nickwiz Daytona Deliberations 9 08-08-2006 06:38 AM
fuel tank ...plastic lined tnsen Classic, Vintage & Veteran 2 06-15-2006 02:12 AM
Plastic Repair Will Maintenance & Workshop Talk 6 06-28-2003 03:10 AM
