If you overfill the tank your check engine light will come on. happens to me constantly. Stop filling before you get to the plastic"neck" inside the tank.
Speed3: is right , wait for 3 heat cycles-completely cold -up to temperature, completely cold again, ect
If your light is still on after that post again and we'll try to get the problem solved for you.
No quarter asked, none given
