Valve Stems - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com Classifieds!SportbikeTrackGearNew Bonneville
Old 12-11-2006, 10:58 PM   #1 (permalink)
Does anyone know if Loctite 767 is ok on valve stems before reasembly?
The Triumph manual mentions MOLYBDENUM DISULPHIDE GREASE.
What is MOLYBDENUM DISULPHIDE GREASE??????????
Bluetiger901 is offline   Reply With Quote
Old 12-12-2006, 04:14 PM   #2 (permalink)
Grease with fine MoS2 powder in it. I usually use synthetic gear oil and a little STP mixed in or an assembly lube.
Mecchanica is offline   Reply With Quote
Old 12-12-2006, 07:34 PM   #3 (permalink)
I believe that is grease that has the dark, graphite color to it. Some what of a multipurpose, high pressure grease reccomended for chassis and front ends and other slow moving componets. Not the best for high speed wheel bearings from what i've read.
Life's too short to ride Jap bikes!
bigern2300 is offline   Reply With Quote
Old 12-13-2006, 12:27 AM   #4 (permalink)
This should answer all your questions about the grease:
http://en.wikipedia.org/wiki/Molybdenum_disulfide
copy and paste the website in the browser it should work
rider955i is offline   Reply With Quote
Old 12-15-2006, 12:26 AM   #5 (permalink)
kubihibi
I use it alot when rebuilding valves on the submarine, it looks like graphite powder and antisieze mixed together. It usually comes in small cans with a brush built into the cap too.
Old 12-18-2006, 10:01 PM   #6 (permalink)
Did anybody here ever use "JB Weld" ???
I have a leaking plastic tank on a 96 Tiger. The leak is where the fastner screw is on the right front lower side and this is where the fairing bolts on to ,or fastens on to the tank. :hammer:
Old 12-18-2006, 10:02 PM   #7 (permalink)
sorry for the last post. I meant it for another topic...
valve/valve guide question GrayMitchell Classic, Vintage & Veteran 4 06-03-2007 02:22 PM
Shortening Stock Directional Stems NoPoz Club Cafe' 1 10-12-2006 07:50 PM
Just checked valve clearances - not waaay off! Any Valve Experts out there? ohiorider Twins Technical Talk 6 07-28-2006 11:37 PM
Longer Mirror Stems for Bonneville??? mecscc Twins Talk 8 02-12-2006 07:49 AM
Valve and valve guides, how much play??? hillclimber Classic, Vintage & Veteran 5 01-03-2006 11:05 AM
