i agree, regular maintenance, i.e. changing the coolant on a regular basis is most important. same goes for engine oil, brake fliud, chain lube, etc. using the most expensive oil or coolant is nice if you can afford it but why waste your money if you do your own maintenance and tend to change fluids look before their extended service life?
