Easy Way To Reduce Throttle Travel? - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearHonda PowersportsNew BonnevilleMotorcycle.com Classifieds!
Old 12-01-2006, 04:51 PM   #1 (permalink)
Is there a way to reduce the total rotation of the throttle grip?
It just seems like if the travel was about 20% less from closed to full open, then it is now, I would like it better.
Its a '02 Bonnie, so not crazy power, wouldn't make it twitchy I don't think. But a little easier on the wrist.... :-D
Ivan
When an objection cannot be made formidable, there is some policy in trying to make it frightful; and to substitute the yell and the war-whoop, in the place of reason, argument, and good order.— Thomas Paine
TheLiveEye is offline   Reply With Quote
Old 12-01-2006, 10:29 PM   #2 (permalink)
I don't know, but i think you'd have to get a different throttle. The runner the cable rides in is the key. the larger the diameter the less you'll have to turn it. maybe you could try filling the groove with tape or something to build it up higher, that is as long as the cable doesn't then rub the housing. i feel the same way in one respect.......it's too long of a turn to get to WOT. On the other hand i think it would make those very slight throttle opening low speed situations overly touchy. Like when you're tirning a corner at 10 MPH.I believe the key would be a steeper ramp in the groove so that it doesn't turn too much at low settings, but then the diameter quickly rises to make the last 1/2 or 3/4 of rotation give more travel with less rotation. I think again the way would be to find a new throttle that has a non linear ramp for the cable. But i know nothing about whether or not you can get anything like that.
Old 12-02-2006, 10:34 AM   #3 (permalink)
Favourite Bike: '01 Speed Triple
I bought a throttle mod kit from a guy in NY, which reduced the twist to 55% of stock. His name is Peter Lute, and you can contact him at SPRINT28@aol.com Maybe it will work on your bike.
Speed3 is online now   Reply With Quote
Old 12-04-2006, 04:13 AM   #4 (permalink)
Favourite Bike: Orange TBS,the fast color
Other Motorcycle: Can there be room for 2?
See if you can find a ramped wheel for the carb end. I'll bet other bikes used this series of carb (a junkyarding we will go...).
Yee-haaaaa!
help please. How to reduce exhaust noise tacomaguy Tiger Workshop (archive) 4 09-29-2007 07:29 PM
Suspension Travel HiVel Twins Technical Talk 2 02-02-2007 01:49 PM
anyone use a helmet to reduce the screen noise BluePuss Tiger Mods & Bolt-Ons (archive) 9 09-30-2006 03:30 AM
Tools for travel rjaston Tiger Mods & Bolt-Ons (archive) 8 08-06-2006 02:09 AM
unarmed travel russerts Twins Talk 8 07-06-2006 10:46 PM
