Turn signal question???? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-01-2006, 03:27 AM   #1 (permalink)
I recently bought a 2004 Daytona 955i and the previous owner installed flush mounts on the front and integrated brake and signal for the rear. They are not leds, but whenever I touch either front or back brake the lights blink faster. Any thoughts????
"GOD hath given you but one face, but you go and make yourself another"
Shakespeare
Dogma is offline   Reply With Quote
Old 12-01-2006, 10:01 AM   #2 (permalink)
Favourite Bike: My TBS of course
zimtok's Avatar
Check your ground wires, and all connectors. Maybe run an additional ground wire directly to the battery.
The only thing the tail,brake, and turn signals have in common is the ground wiring.
My life is based on a true story.
www.throttlejockey.co.uk
zimtok is offline   Reply With Quote
Old 12-01-2006, 08:42 PM   #3 (permalink)
Favourite Bike: 2002 Tiger
pineygroveshop's Avatar
I installed led turn signal lamps and replaced the relay with it as a kit. Without the new relay, the lamps flashed much faster.
Cheers,
Stephen Ford
pineygroveshop is offline   Reply With Quote
Old 12-02-2006, 09:58 PM   #4 (permalink)
Favourite Bike: '02 Sprint
Dogma,
In my Sprint wiring diagram, the brake circuitry is wired into the flasher unit - beats me why, though.
The rear brake light has three wires - one ground, one to the flasher via the brake levers and the last to the fuse box. I wonder if the previous owner reversed the flasher and ignition wires.
On the Sprint, the three wires from the brake light unit to its plug are black, red and blue. At the plug, black mates to black (ground), red to yellow and blue to GP (green/purple?). The yellow goes to the fuse box, GP to both the front and rear brake lever switches. The other lead from both brake lever switches (orange/green) goes to the flasher unit.
I hope this helps,
Bern
PaloAlto is offline   Reply With Quote
Old 12-03-2006, 04:31 AM   #5 (permalink)
New light possibly changes the resistance in the circuit causing increase in blinking speed.
Jhumphrey is offline   Reply With Quote
Turn Signal Replacement Question Crimelab Twins Talk 5 02-05-2008 08:05 PM
Stock turn signal question Kramocker Twins Technical Talk 7 01-13-2008 09:40 PM
Turn Signal Question... Brandon_Rice Twins Technical Talk 2 11-07-2007 09:56 PM
New to the S3 Family...Turn Signal Question... Plague1050 Speed Triple Forum 5 12-21-2005 05:22 PM
turn signal question Tsalagi Maintenance & Workshop Talk 18 09-08-2003 01:12 PM
