For the hamfisted DIYer - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-27-2006, 01:41 PM   #1 (permalink)
When I bought my T300, the oil plug bolt allen head was about half stripped. So, I finished the job.
I was considering a chisel when I stumbled across a set of tools called "Sock-It-Out". These are allen head keys that are beveled or tapered at one end. The tapered end is hammered into the stripped allen head until tight. Then you put a wrench (spanner) on the other end and remove the damaged bolt. It works very well. They cost about $67 for a set of 4 (6mm, 8mm, 10mm, and 12mm).
Try here edco tools or here Nolan Supply.
Zip
"You don't know what you don't know."
zippythehog is offline   Reply With Quote
