AI removal - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-24-2006, 06:19 PM   #1 (permalink)
Has anyone here bought and used the air injection removal kit from newbonneville?What did you think?Is it worth it?
akenaten is offline   Reply With Quote
Old 11-27-2006, 02:57 PM   #2 (permalink)
mt690
Yes, I bought the aluminum black bolts to close off the AI ports. Provides plenty of room to change plugs. You may want to use a small amount of sealer for the caps that are installed on the intake runners beacuse they fit rather loose and will pop off during a backfire. Be sure to turn the idle mixture screws out to richen the mixture once you perform the procedure to eliminate the backfire problem. Everything you need is in the kit, and well worth the money.
Ai Removal DaveE Maintenance & Workshop Talk 1 07-23-2007 06:32 AM
Restrictor plate removal or air box removal ? BON17 Twins Technical Talk 1 07-07-2007 11:40 AM
AI removal Troh23 Twins Talk 18 07-31-2006 07:04 PM
AI Removal (again) SbGunslinger Twins Talk 6 04-11-2006 01:38 PM
Spring Mods--Predators, Airbox Removal, AI Removal idaho_thrux Twins Talk 6 04-09-2006 04:30 PM
