adapting wheels from one bike to another - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-14-2006, 01:57 PM   #1 (permalink)
Legend
Favourite Bike: 904cc Bonnie w/magwheels
sweatmachine's Avatar
I'm going to buy a set of take-off wheels from a Harley Dyna Low rider, they're mags and setup for a single front disk and the rear has the single disk and the pulley for the belt drive.
Obviously I'll have to yank the pulley for a sprocket, and since the Bonnie is Right Side Drive I may have to either turn the wheel around (and flip the tire) or swap the pulley for the rotor, and the rotor for my sprocket.
other than axle spacers, speedo drive, and possibly having to custom drill/machine my brake rotors and rear sprocket, what other problems could I run into?
The bonnie's wheels are 19'' and 17'', and I think these HD wheels are 19'' and 16''. I'd think a 16'' rear wheel with a tall tire would be the same as a 17'' rear with a shorter tire, basically I think the difference would be negligible. Maybe I'd get a lower ride height by a 1/8'' which would be ok by me, and it may affect my gear ratio a small amount, and that's ok too.
Any experts out there that can sway me one way or the other? I'm getting these wheels in great shape with all the rotors/pulley intact (which I won't need) and with some decent rubber on them.
Thoughts?
I'd just like to have mag wheels to avoid tubes and broken spokes, and it would look cool.
Old 11-14-2006, 04:29 PM   #2 (permalink)
My only question is ...why ?
Lone-Rider is offline   Reply With Quote
Old 11-14-2006, 08:58 PM   #3 (permalink)
Favourite Bike: 05 Black Speedmaster
Because it would look real cool, go for it sweat. If you have to pull the tires you may as well powder em black while they are off. Taking mine to blast and drop for powder black tomorrow. Can't see any situation coming up that you didn't mention, spacing is the most crucial and shimming the rotors or caliper mounts of course. Child's play, have fun.
Old 11-18-2006, 01:14 AM   #4 (permalink)
Me, I just wouldn't do it. Partly because I think Harley mags look like something that will appear as "****" on this forum, & partly because I think mixing SAE & metric is another headache on top of the rotor/sprocket problems you already mentioned. I'm sure it could be made to work, but I'd want a 5- or 7-spoke metric mag from an '80s Japanese bike instead of the 29-spoke abominations Harley uses if I was going to go to all that effort. :-D
Hmm, I guess my objections are mostly aesthetic in nature. :razz:
Oh, and I'm pretty sure you will have to flip the wheel. The cush drive side of the wheel is usually pretty different from the rotor side.
Cheers,
-Kit
Old 11-18-2006, 09:15 PM   #5 (permalink)
Favourite Bike: 04 Bonnie black
DO IT !! I`m lonely. :-D
rodburner is online now   Reply With Quote
Old 11-18-2006, 09:44 PM   #6 (permalink)
Cheers,
-Kit
That brings up a good point. AFAIK, it doesn't have a cush drive, so more driveline shock will be transmitted to the transmission. The belt drive absorbs enough shock, so it isn't needed. Don't know if that would be a problem on the Bonnie. Sportsters have never had a cush drive, even in the chain days. I think the V-rod is the only HD that uses one.
Joe-Dirt is offline   Reply With Quote
Old 11-20-2006, 04:37 PM   #7 (permalink)
Legend
what's a cush drive?
Old 11-20-2006, 06:26 PM   #8 (permalink)
Favourite Bike: '06 Bonneville Black
SCCTrim's Avatar
Other Motorcycle: '89 FXR
I seen one on the neighbors ride when he had it apart...if it's what I'm thinking it's a sort of large rubber bush if you will that absorb's drivetrain shock inside the rear sprocket assembly.
Think of it as a damper for the driveline itself.
http://nailyourtrim.com
SCCTrim is offline   Reply With Quote
Old 11-20-2006, 06:52 PM   #9 (permalink)
Here is my S4 rear wheel. The sprocket bolts to the silver center piece which slips into the rim. It "floats" on rubber spacers, which cushions driveline shock. Does a new Bonnie use something similar?
Old 11-21-2006, 02:22 PM   #10 (permalink)
Favourite Bike: My '03 America
agogel's Avatar
Joe,
Yep, the Bonnie's use the same setup.
As a matter of fact.....all Triumph's of the new-age seem to use this setup.
Tony G
"If you don't get what you really want, it's your own fault"
agogel is offline   Reply With Quote
Carrozzeria Wheels vs wire wheels MAR Club Cafe' 8 12-17-2008 03:36 PM
Adapting a Renntec Rack and Grab Rail to a Scrambler? RowlandPhysics Twins Technical Talk 4 12-28-2007 08:00 PM
Wheels welshrob Sprint Forum 9 08-22-2006 07:52 AM
some new wheels for ya tartan Twins Talk 6 06-21-2006 08:54 PM
mirrors and adapting them to the speedy? dazco Twins Talk 3 12-22-2005 04:34 AM
