S3 fuel connectors - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario TourismHonda PowersportsNew Bonneville
Old 11-13-2006, 04:31 PM   #1 (permalink)
The return fuel line connector has snapped on my S3.
Do these just screw into the tank? Is there a torque setting for them? I wouldn't want to snap a new one when replacing it.
9264 is offline   Reply With Quote
Old 11-13-2006, 10:14 PM   #2 (permalink)
Favourite Bike: '01 Speed Triple
There is no torque setting. I replaced mine with good metal ones. If you replace them yourself, Drain the tank, remove it and put it on a thick blanket on a bench. Mark the direction each one is pointing with a marker on the plate, and see how many threads are showing so you can thread the new one approx. the same amount. You can reuse the old gasket, but I would just get a new one. Wrap the threads with teflon tape before you reinstall, and torque each little bolt to spec. I think it's 6 Nm, but look it up. And Bobs your fathers brother!
Speed3 is offline   Reply With Quote
Old 11-14-2006, 05:33 AM   #3 (permalink)
Thanks for the reply. Much appreciated.
I was hoping to do this with the tank still on the bike. Is it possible?
Old 11-14-2006, 02:19 PM   #4 (permalink)
I don't think so. Those things are in there very tightly. It's easy to remove the tank anyway.
Old 11-14-2006, 04:47 PM   #5 (permalink)
thanks again
Old 11-15-2006, 09:23 AM   #6 (permalink)
Well just to close this one out - I phoned the supplying dealer yesterday. They said they would collect the bike and fix it under warranty. They are not my nearest dealer and are some 50 miles away.
A van turns up this morning. Out gets a mechanic with toolbox and parts. Replaces the fuel connector on my driveway. All done and dusted.
Great service and a big thank you to On Yer Triumph.
Those Fuel Connectors CaMojo Tiger Workshop (archive) 3 05-06-2007 07:20 PM
955i Fuel Connectors Captain_Rat Speed Triple Forum 2 09-24-2006 10:23 PM
Fuel Connectors NODDY Sprint Forum 7 07-12-2005 12:20 PM
Plastic fuel connectors offroad55 Tiger Chat 10 04-06-2005 05:52 PM
Fuel Pipe Connectors matdav Sprint Forum 25 06-17-2004 08:23 PM
