sprint wont idle,,,help - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports New BonnevilleMotorcycle.comSportbikeTrackGear
Old 11-01-2006, 11:11 PM   #1 (permalink)
meanolddog's Avatar
after a brisk run home from work today my sprint has decided not to idle. im perplexed. lately it has not seemed to want to idle down immediatly when i pull on the clutch, now this. anyone else experiwence this before??
"I see angels on Ariels in leather and chrome
Swooping down from heaven to carry me home"
meanolddog is offline   Reply With Quote
Old 11-01-2006, 11:42 PM   #2 (permalink)
klc
Tell us more info. How many miles? Any services done lately?Any mods done recently? Did it start all at once or little at a time. Change of fuel? Almost sounds like a air leak
klc is offline   Reply With Quote
Old 11-01-2006, 11:57 PM   #3 (permalink)
meanolddog's Avatar
its a 2000 st. no mods or changes and it just happened all at once.
Old 11-02-2006, 10:53 AM   #4 (permalink)
The idle on the Sprint is controlled by the IAC (idle air control??) valve. A lot of FI engines use an IAC and over time they can get gummed up, or have a vacuum hose fall off.
Your issue sounds like an IAC issue. Unfortunately the IAC is under the tank, and hard to get a look at. I would start by looking for a loose hose. If the problem started as suddenly as you mention, a vacuum hose might have come loose off the IAC.
robadele is offline   Reply With Quote
Old 11-04-2006, 12:06 AM   #5 (permalink)
meanolddog's Avatar
problem solved with a new TPS andidle control sensor and housing.
and a new map from Shel
fast idle on '00 Sprint St Suncoast Sprint Forum 1 07-03-2007 04:43 PM
all of a sudden, sprint wont idle??? meanolddog Sprint Forum 5 11-04-2006 12:04 AM
1995 Sprint wont start T3 Sport / Touring Forum 4 05-25-2005 09:38 AM
sprint st wont start Sprint Forum 2 03-28-2004 10:22 AM
HELP. SPRINT ST WONT START Maintenance & Workshop Talk 6 03-28-2004 03:29 AM
