Hiding wires in handlebars - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.com Classifieds!Honda PowersportsMotorcycle.com
Old 02-25-2006, 03:30 PM   #1 (permalink)
dardoonk's Avatar
I am mounting drag bars that have holes for hiding the wiring. What the heck is the best way to do this?
Should I cut each wire and solder them all back together when I get them thru the bars, or should I remove each connection from the plastic plug in the headlight and try to put them all back together when I finish?
Then, how do I get the wires past the bend in the bars?
I've gotten this far in life by refusing to act more than half my age, and I intend on continuing this way.
My Photos
'05 America- Works' suspension, Freaked, D&D's, 150 mains, 42 pilots, TBS needles, 1 shim
dardoonk is offline   Reply With Quote
Old 02-25-2006, 07:30 PM   #2 (permalink)
Favourite Bike: Triumph
johnyC's Avatar
I've never gone to the trouble of hiding all the wires in the bars, but I had to thread the wires for the heated grips through when I fitted Renthal bars to my Tiger.
I removed and later re-attached the connector ends of the heater wires, you would have to do the same, or cut the wires and fit in-line connectors or solder them once you've got them through the bars.
You need to install a 'fish' to haul the wires through first. Feed a length of wire back up the bars through the exit hole and attach the switch wires to it. If you have trouble getting it out of the entry hole, use a wire hook to pull it out. I used the head of a bicycle spoke. Another method I used when fitting heated grips to a BMW, was to attach a thread to a small nut and drop it down through the bars, you'd have to take the bars off the bike though.
Because I had no way of cleaning the inside edge of the drilled holes, I also inserted some plastic tubing to act as a conduit, to prevent chaffing of the wires.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 02-25-2006, 10:27 PM   #3 (permalink)
I hid all the wiring when I changed out the handlebars on my Harley. It's easy.
If you can use the same wire and put the quick disconnect plugs back together that's probably best. I cut and soldered mine back together, but my new bars were shaped differently from old ones so I had to add wire.
Use a small file on the holes to make sure they are smooth and won't wear through the wire. To get the wire through I pulled a strong but light string through as a guide. Then I tied the wires to the string and pulled them through. I taped all the holes except the entry and exit holes and used a vacuum cleaner to suck the string through the bars. Works like a charm.
This will really clean up the look of your bike. Good luck.
Steve
Ride to Coffee
Coffee to Ride
Blog
Caffeinated is offline   Reply With Quote
Hiding in Hawaii mjtool Biker Hang-Out 15 08-16-2007 05:54 PM
Running / Hiding Wires whodkne Speed Triple Forum 0 07-17-2007 12:07 AM
oil leak hiding TravelinManOhio Hinckley Classic Triples 3 04-08-2007 12:05 PM
Is this where the mixture screws are hiding? SpeedyPete Twins Talk 4 10-15-2005 12:12 AM
Can anyone tell me where these wires go? Sprint Forum 6 06-24-2004 03:54 PM
