Tune-up Questions - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!
Old 02-17-2006, 07:38 PM   #1 (permalink)
INTRODUCTION:
The Subject is a 96 Sprint. So I thought it best to change the airfilter. You must take the carbs off to change the airfilter....hmmm. Well while I'm here I thought to adjust the valves, and check the plugs.
BODY:
After pulling the plugs, I find them all the wrong heat range- all cooler. The one and three are 9ea-9, number two cylinder is 9ea. The middle one has a lot of soot and a weird grey/brown mass on one side of the electrode. Only number three looks sort of normal.
QUESTION: Anybody have any idea why the previous owner or mechanic did this? Mileage is mediocre at best (36mpg).
Also, has anybody heard anything wrong with using used shims (measured & confirmed thickness with a mic) on the motor?
Thanks,
Zip
"You don't know what you don't know."
zippythehog is offline   Reply With Quote
Old 02-18-2006, 09:49 AM   #2 (permalink)
cooler plugs reduce the likelyhood of pre-ignition or electrode melting. the middle cylinder normally would be hotter becuase of it being surrounded by hot cylinders, so it is not unheard of to run cooler plugs in inboard cylinders, but it is normaly not neccesary.
36MPG implies that is running a bit rich, and that may be because of the air filter(s?) being dirty.. I wouldn't make any adjustments to your mixture before you do the shims and plugs and filter.
the weird grey/brown mass is probably evidence of a bit of oil burning.
An intelligent man is sometimes forced to be drunk to spend time with his friends.
--Ernest Hemingway
Cerberus is offline   Reply With Quote
Old 02-18-2006, 10:02 AM   #3 (permalink)
Favourite Bike: 02 Daytona CE
flatspins's Avatar
Other Motorcycle: Vincent Rapide
Extra Motorcycle: Specialized Big Hit
As long as you measure each shim there is nothing wrong with reusing them.....provided they don't have any deformities or serious wear on them.
If you don't stand behind our troops, Please feel free to stand in front of them.
flatspins is offline   Reply With Quote
Old 02-18-2006, 11:13 AM   #4 (permalink)
Thanks all
Race Tune vs. Off-Road Tune- Mattsy Tiger Workshop (archive) 24 03-27-2009 12:21 PM
tridents to tune or not to tune ???? scoobydoo Sprint Forum 4 01-13-2008 03:06 PM
TORS tune from dealer or Tuneboy tune? Max_NYC Speed Triple Forum 25 07-06-2007 11:22 PM
Daytona 675 Questions & Inline 3 Questions TeddaGreek Daytona675 Forum 11 12-28-2006 12:18 AM
TuneBoy tune questions RandyL Sprint Forum 1 05-07-2006 06:42 PM
