Brake Caliper Pistons - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-12-2006, 12:00 PM   #1 (permalink)
Favourite Bike: 94 Speed triple Black
Fridgehq's Avatar
Other Motorcycle: 2004 955 Daytona Red
Extra Motorcycle: RD350 YPVS being restored
Can anyone give me some advice, I have looked at my front brake caliper pistons and there appears to be some pitting about 4 mm from the top of the piston. Do I have to replace those or can they be rubbed down???
Fridgehq is offline   Reply With Quote
Old 02-13-2006, 11:30 AM   #2 (permalink)
Favourite Bike: My Sprint
superfour's Avatar
Other Motorcycle: My Peugeot 10 speed
Yes you could rub them down and get a couple of months further use.That said you will end up doing it again and again,as the corrosion returns.It is best to replace the pistons and seals.Expensive but job done.
Currently riding a red ST 1050
Stuart
superfour is offline   Reply With Quote
Old 02-13-2006, 01:48 PM   #3 (permalink)
Slinky's Avatar
If you are going to change the pistons it might be worth the extra cost of using stainless steel. They are probably not much dearer than Triumph's prices anyway.
www.wemoto.com should have them.
Old 02-13-2006, 06:35 PM   #4 (permalink)
Favourite Bike: Orange TBS,the fast color
Other Motorcycle: Can there be room for 2?
Fairly easy to do on most vehicles (gets funny when they have parking brakes, but this is a bike). You will need a thin piece of wood (or non metal plank), some air to pop the piston(s), a way to clean them (brake cleaner; remember asbestos warnings), and some fine emery cloth or sand paper (change paper often). The paper is to clean the bore, which will likely have a ring of crusted brown/black material. It wont take much to clean, but the new piston assembly may otherwise stick or hang. I had an old Dodge pickup that had phenolic/plastic pistons. Much better than the metal I replaced it with (chipped a piston by not using a wood block when I blew out the piston). alternative to the paper include a reamer, but these are hard to find. For iron/steel calipers (trucks and older cars) you can use a hone, but the stones will load up with aluminum.
You will also want some nitrile (better than rubber) gloves. Take the parts off of you bike before disassembling (keeps the brake fluid from your paint).
Others may have more experience with this. I wouldn't bother with the corrosion if it isn't getting inside the caliper bore, as the dust seal should stop it. Just clean and monitor. Can you get a bit of somekind of thin paint or sealer on it? The piston will only conitinue to be exposed as the pads wear, so it probably isn't necessary until the pads are replaced.
Have fun!
Mojo
Yee-haaaaa!
TBS Caliper Pistons NeilD Hinckley Classic Triples 6 09-04-2007 12:55 AM
Brake Pistons kek Sprint Forum 5 04-08-2007 12:07 PM
New brake pistons Spendthrift Speed Triple Forum 0 01-06-2007 01:17 PM
Compressing Caliper Pistons? tmccullion Maintenance & Workshop Talk 5 05-10-2004 09:36 PM
Compress caliper pistons? tmccullion Trophy 1 05-08-2004 09:11 PM
