Is it the coil ? - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearHonda Powersports
Old 02-05-2006, 01:08 PM   #1 (permalink)
BadDog
My speed triple hasn't been used greatly this winter, as such the battery has discharged (down to the datatool alarm methinks ?).
I put it on an optimate battery conditioner and all seems good, however, it is very difficult for me to start the bike from the battery from scratch. I have to use a battery jump start each time. Once the engine's warm the baterry will kick the engine over, but only seems to give a relatively weak spark compared to the jump start.
I've been told it could be the coil breaking down, what do you think ?
I also seen to remember somebody telling me of problems with speed triples if their battery discharges, but I can't remember what it was.
Please help !
Thanks :???: :???:
Old 02-05-2006, 01:18 PM   #2 (permalink)
Slinky's Avatar
It sounds more like a duff battery. Did you charge it over the winter? If a battery has been deep discharge it can lose it's ability to hold a charge. A cold start will always need a much healthier battery than a hot start.
Off topic- I have just spent an entertaining afternoon in the garage, trying to start my Tbird, which has not been used for 3 months. After several attempts at charging the battery and jumping it, there was no sign of it firing.
After a few hours of this I eventually I figured out that there was no fuel in the tank... :razz:
Old 02-05-2006, 01:33 PM   #3 (permalink)
BadDog
The battery has been toppep-up with distilled water, and the optimate gives it a clean bill of health.
Is it still possible that the battery's knackerd ? :???:
Old 02-05-2006, 01:35 PM   #4 (permalink)
definitely sounds like a tired battery.
deep cycling a battery ruins it.
gel cell or AGM batteries are great for their durability and power output
An intelligent man is sometimes forced to be drunk to spend time with his friends.
--Ernest Hemingway
Cerberus is offline   Reply With Quote
Old 02-05-2006, 01:36 PM   #5 (permalink)
the optmate cannot load test the battery, so its evaluation is somewhat meaningless.
--Ernest Hemingway
Old 02-05-2006, 02:41 PM   #6 (permalink)
When I fired my S3 up last week, it didn't turn over as fast as normal. When I took the battery off to charge it, the meter on the charger didn't register the battery as being as discharged as it appeared to be.
Since the battery is now nearly six years old, I reckon it's time for a new 'un......
If yours is a similar age, like what previous posters have said, you probably need a new battery.
Hello Cerbs.... :wink:
[ This message was edited by: Bob955i on 2006-02-05 12:42 ]
Bob955i is offline   Reply With Quote
Old 02-05-2006, 07:22 PM   #7 (permalink)
On 2006-02-05 12:41, Bob955i wrote:
...Hello Cerbs.... :wink:
QUIT FOLLOWING ME!
:-D
--Ernest Hemingway
Old 02-08-2006, 03:03 PM   #8 (permalink)
QUIT FOLLOWING ME!
:-D
I was here first na na na :razz:
Old 02-08-2006, 05:03 PM   #9 (permalink)
Skidpan's Avatar
I'm not an expert, however, I had the same trouble with a T3 900 Daytona. The optimate and a multimeter would show it as being healthy, 13 volts or so after a night on charge, but it was weary at starting the bike. A new battery fixed it, period. It seems to me like a battery can have 12 healthy, arse-kicking volts, but it could have 12 of the weariest, thin, useless volts, and the kit I have can't tell the difference. So far as the multimeter is concerened, 12 volts is 12 volts, and the quality of them is open to doubt. Replace the battery.
The Oboto Sobatmas - The Finest, Most Exclusive Gathering of Gentlemen Motorcyclists. Sponsored by Deuchars, Fuelled by Stupidity...
The Obo Scribe mutters at http://obotosobatmas.blogspot.com/
Skidpan is offline   Reply With Quote
Old 02-13-2006, 07:00 PM   #10 (permalink)
Favourite Bike: 1996 Daytona 1200
daytonacharlie's Avatar
BadDog,
I had the coils go bad on my '96 Daytona 1200 at around 30,000 miles. The symptoms of a bad coil are poor low rpm performance once the bike has warmed up, a clatter (like valve clatter) at low rpm, poor gas mileage and fouled plugs. I replaced my coils (D12's have 2, Speed 3's have 3) and problem solved. I agree with everyone else your problem sounds like a bad battery.
good luck,
Charles
daytonacharlie is offline   Reply With Quote
Coil voltage and coil oil? kawtoy Classic, Vintage & Veteran 6 07-13-2006 11:35 AM
coil ??? ronniena Hinckley Classic Triples 2 06-11-2006 01:59 PM
HELP - coil problem? walshja Hinckley Classic Triples 10 09-20-2005 02:34 PM
It was the coil Mark62 Trophy 1 07-14-2005 12:52 AM
Help Help on coil Daytona Deliberations 1 05-07-2004 10:09 AM
