Slipper Clutch for Sprint RS? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-31-2006, 12:46 PM   #1 (permalink)
this is a crosspost from the Sprint forum, but since no one answered there, I'll ask here.
I want to know if there are any companies making slipper clutches for the Sprint RS. I also have a buddy interested in one for his ST, so any help locating one would be appreciated
Life is not measured by the number of breaths we take, but by the moments that take our breath away.
skrap1r0n is offline   Reply With Quote
Old 01-31-2006, 04:51 PM   #2 (permalink)
heres another question whats a slipper clutch, I have also herad of a lock up clutch, just while where at it.
mrcheese is offline   Reply With Quote
Old 01-31-2006, 05:46 PM   #3 (permalink)
a slipper clutch allows you do downshift as far as you want and let out the clutch without fear of locking up the rear wheel. It helps with the hard braking at the track. Ya know, when you wanna go from 140 to 70 in order to make that turn.
Old 02-01-2006, 12:23 AM   #4 (permalink)
Sorry skrap1r0n for high jacking your thread Im sure some one will have the answer for you, Another while where at it can the TT have a slipper clutch, And what about this lock up stuff. :-D
Old 02-01-2006, 11:01 AM   #5 (permalink)
No worries on the hijack, I do it all the time :razz: .
At any rate, re: the lock up stuff, in the event you're not referring to the lock up clutch and referring to the wheel locking, If you're travelling at higher RPM's and downshift, the RMP will of course increse. There have been times during hard downshifting that the rear wheel is unable to turn fast enough to keep up with the bike. It's technically not a lock up like if you slammed the rear brake, but it can cause the rear wheel to slide.
If your on the track, in a straight and wound out running in the 130-140 range and approaching a turn, you need to scrub a LOT of speed. Gearing down while braking hard allows you to do it. The problem is, if you're wound out and in the red in 6th and try to downshift while braking, you can slide the rear wheel. This tends to increase the pucker factor going into the turn.
Old 02-01-2006, 02:18 PM   #6 (permalink)
Slinky's Avatar
The 1050 Speed Triple has a slipper clutch, it may fit in the earlier 955 motors.
Slinky is online now   Reply With Quote
Old 02-02-2006, 10:48 AM   #7 (permalink)
Favourite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
just as an FYI,
the manufacturers are no longer calling them slipper clutches, they are now oficially:
Back Torque Limiting Clutches
you might find more luck doing searches on these. I know they make them for wet clutch applications, since the only difference is elongated and ramped holes in the Clutch basket and pressure plate.
check:
http://www.hmracing.co.uk/default.asp :-g
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
chefjpd is offline   Reply With Quote
Old 02-02-2006, 01:16 PM   #8 (permalink)
thanks chefjpd, thats good info. I'll do a search using those terms. If I find something I'll post it.
Does 07 ST have a "slipper clutch" ? TheNomad Sprint Forum 9 07-02-2007 08:40 AM
Slipper Clutch? fivehundo Daytona Deliberations 7 02-03-2007 03:34 PM
Slipper Clutch???? What is it???? Rayzor61 Maintenance & Workshop Talk 8 01-02-2007 02:49 PM
Is there a slipper clutch available for the 05/06 S3???? Beyote Speed Triple Forum 6 10-27-2005 06:22 PM
Does the S4 have a slipper clutch? pokey Triumph SuperSports 1 06-29-2005 04:57 PM
