Resistance at fuel level sender? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-26-2006, 10:40 PM   #1 (permalink)
Favourite Bike: 01 Tiger
Other Motorcycle: 02 Sprint RS
Extra Motorcycle: another 01 Tiger
The low fuel light on my 02 RS is on all the time. I think it is probably in the wiring harness but would like to check out the sending unit (or simulate) the sending unit 1st.
What sort of resistance values values should I be measuring across the leads?
Is it like most cars sending units, basically open circuit when full with increasing resistance as it empties. Or the other way round?
Thanks
Charlie
nortoncharlie is offline   Reply With Quote
Old 01-28-2006, 06:26 AM   #2 (permalink)
trafficfixr's Avatar
Charlie, if you think the problem is in the harness and not the sender itself then just disconnect the sending unit. If the problem is in the harness, the light will stay on because the short will still be in the circuit. If it goes out, get a new sending unit.
trafficfixr is offline   Reply With Quote
Old 01-28-2006, 11:09 AM   #3 (permalink)
Check the float first. I had to replace mine on my 2001 st. The float is WAYYYYY less expensive to replace than the sending unit.
"GOD hath given you but one face, but you go and make yourself another"
Shakespeare
Dogma is offline   Reply With Quote
Old 01-28-2006, 11:33 AM   #4 (permalink)
Well, I unplugged the sending unit and got the check engine light on and the low fuel light stayed on as well. Plugged it back in and the check engine light went out after a few warm ups. So my guess is the wiring is OK.
Dogma, I'll check into the float. I wonder if I could hook the float and lift it manually through the filler neck?
Old 01-28-2006, 01:16 PM   #5 (permalink)
Negative, You will have to pull the tank off the bike to get to the float. Held on with four bolts and a rubber gasket. It's easy to remove just timely. Then you can just tip the float holder upside down and it will slide right out, if it's not stuck? You can also hook the wiring back up (once removed from the tank) to test the float manually by hand by sliding the float up and down slowly to check the connections.
Shakespeare
Leaky fuel sender - anyone manage a repair? cm08 Sprint Forum 9 01-10-2007 02:17 PM
help- fuel sender-955 injected jabrady1234 Speed Triple Forum 0 06-21-2006 01:20 PM
Fuel sender (guage) not working (New owner) Robdan Sprint Forum 5 06-11-2006 08:35 AM
Fuel gauge sensor resistance iansoady Tiger Workshop (archive) 2 04-29-2006 12:58 PM
Float level / Fuel Level for 1998 Trophy 900? CharlestonRider Trophy 8 06-04-2005 05:07 PM
