OK,
in order to make your turn signals into running lights, you first need dual filament sockets and bulbs in the turn signals. Check to see what you have first. You can wire the front signals to the headlights, and the rears to the tail light.
A less messy solution might be a convertor box, I think sold by Kisan Technologies. This is a common mod on touring bikes, so you might check Goldwing or BMW accessory sites.
Also, are you sure your headlight is actually on during ing? Most of the Triumph models have headlight cutout relays that shut the headlight while starting in order to put less drain on the battery.
good luck :-g
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
