Stripped Hex Screw on Front of Tank - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGear
Old 12-27-2012, 09:38 AM   #1 (permalink)
Main Motorcycle: 2012 Street Triple R
mfile2000's Avatar
Other Motorcycle: 2000 Sprint ST
Help!
I have a 2000 Sprint and need to get the tank off, but the hex hole in the screw at the front of the tank is rounded out. What's my best bet to get that thing out of there?
Thanks all.
mfile2000 is offline   Reply With Quote
Old 12-27-2012, 10:16 AM   #2 (permalink)
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: '01SV650S sold
Try to tap in a slightly larger torx style driver or maybe grind a slot and use a flatblade screwdriver.
Felony is offline   Reply With Quote
Old 12-27-2012, 10:24 AM   #3 (permalink)
Main Motorcycle: Moto Guzzi 1200 Sport
Other Motorcycle: 1972 Suzuki Hustler
Sometimes, an Imperial hex key will fit (helped along with a few gentle taps with a hammer). The trouble is, if the hex is rounded off, it was probably seriously overtightened, so will be a right royal PITA to remove, whichever method you employ. Best of luck!
M.G.Vig is offline   Reply With Quote
Old 12-27-2012, 10:32 AM   #4 (permalink)
Main Motorcycle: Triumph Sprint 2006
Other Motorcycle: Ducati 900SS 1993
drill a hole thru the center of the screw to relieve tension and use an easy out.
matjen is offline   Reply With Quote
Old 12-27-2012, 10:44 AM   #5 (permalink)
mfile2000's Avatar
Thanks everyone. On the Sprint, there isn't much room to work in the front of the tank, given the fact that the tank rises high above the screw with just a groove in the front of the tank to get to it.
Old 12-27-2012, 01:23 PM   #6 (permalink)
Main Motorcycle: My RED '02 Sprint ST
CharlieS's Avatar
Other Motorcycle: 99 Thunderbird Sport
Use a drill bit to drill the head of the bolt off. 1/4" ought to do it. The head will pop off once you drill thru it, then you can remove the tank and use a pair of pliers to ease the remaining bolt from the threads.
---Charlie
CharlieS is online now   Reply With Quote
Old 12-27-2012, 02:06 PM   #7 (permalink)
KD5QOQ's Avatar
Great minds think alike Charlie.
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
KD5QOQ is offline   Reply With Quote
Old 12-27-2012, 02:09 PM   #8 (permalink)
Main Motorcycle: 2005 Sprint ST 1050 Blue
DrTriumph's Avatar
Drill it just slightly then easy out. I found a snub nose easy out at Canadian Tire that did the job for me on a similar problem. I did have more room it was a pinch bolt.
Dr Triumph
My Photo's...
DrTriumph is offline   Reply With Quote
Old 12-27-2012, 02:40 PM   #9 (permalink)
mfile2000's Avatar
Sounds like the 1/4" drill plan. I ran into this problem because the tank expanded (ethanol) in the gas to the point where it doesn't fit down inside the frame anymore. So the knucklehead I am, last time I put it back on....well, you know the rest of the story.
Old 12-28-2012, 10:47 PM   #10 (permalink)
mfile2000's Avatar
1/4 inch drill did the trick. Just a few seconds. Thanks all again!
Stripped screw head help ffry63 T3 Sport / Touring Forum 16 04-14-2012 12:45 AM
Stripped Screw--HELP! Garage-Dog Twins Technical Talk 12 09-13-2009 11:44 AM
Front brake reservoir stripped screw - Whats your expert advise? LIJ Twins Technical Talk 8 06-18-2009 01:46 AM
Stripped Screw randm Twins Technical Talk 4 08-27-2007 07:33 PM
Found a stripped screw on my gas tank ring mount noobcorpse Sprint Forum 12 08-02-2007 07:14 AM
