Motor Stuck? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-12-2006, 08:04 PM   #1 (permalink)
Feeble_Knievel
I have a t140 engine that won't turn. It was running fine, then it stopped, thunk.
Here is the weird part. The rods and crank seem ok. The cams don't seem to be damaged. I pulled the cylinders off- pistons are fine. The transmisson will change gears. So I figured the clutch is froze so I pulled the primary cover off and took out the clutch plates. Still won't move.
Any ideas?
Old 01-12-2006, 08:57 PM   #2 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
Did you pull the timing side cover off to check if anything is amiss in the cam gears (broken tooth, etc)? Also, the alternator may have frozen up, but that's pretty far fetched. Or, maybe it's seized a bearing.
Just the wisdom of a fool speaking: Jim
Jim Ballard
jimballard is offline   Reply With Quote
stuck fastener sprintboy Daytona675 Forum 6 11-15-2007 10:59 PM
Stuck starter dogarajo Daytona Deliberations 10 11-12-2007 08:06 PM
Speedo stuck on 0 Stampy Triumph SuperSports 3 10-26-2007 12:45 PM
one stuck silencer djw Classic, Vintage & Veteran 11 06-07-2007 11:01 PM
Stuck Throttle jonkull Classic, Vintage & Veteran 11 12-13-2006 04:28 PM
