What's in your motorcycle tool bag? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-08-2012, 02:19 PM   #1 (permalink)
Main Motorcycle: 1966 Triumph Bonneville
T I'm curious as to what tools you guys carry in your tool bags in the event of having to do a little roadside maintenance/repair, especially those of you with the older bikes. What has come in most handy in a pinch?
Mike66 is offline   Reply With Quote
Old 11-08-2012, 03:04 PM   #2 (permalink)
Main Motorcycle: speed triple
In my back pack I have a Leatherman Super Tool 300, imo are well worth it 19 in 1
Mag lite mini with led bulb
Zip ties in various sizes and duct tape not really a first thing you would consider but it does help in a roadside emergency half the time , a small rachet with an extension and a small tool set of sockets.
And a few tire plugs (not the smartest idea for a motorcycle but if it will get you off the shoulder from interstate to the nearest exit, I think it'll be ok at low speed for a mile or two or to just get home)
Short of carying your full toolbox what I keep on me will fix.9/10 of the issues you might encounter
sem_speed3 is offline   Reply With Quote
Old 11-08-2012, 03:21 PM   #3 (permalink)
Main Motorcycle: 2010 15th ann. Spd Triple
JOHNTBS's Avatar
Other Motorcycle: 2010 T-100 Jet Black
Extra Motorcycle: 1995 T309 speed triple
I carry: multi tool,sockets 8mm,10mm,12mm,13mm, foldable Allen wrenches,flashlight, ductape, zipties,screwdriver with multiple tips,extra eyeglasses, advil, alcohol swabs,cable lock for my helmetand a few shoptowels.
Sent from my ADR6300
JOHNTBS is offline   Reply With Quote
Old 11-08-2012, 08:05 PM   #4 (permalink)
Main Motorcycle: T100
Dan McGrath's Avatar
Other Motorcycle: basket case Honda Scrambl
My cellphone, Maglight, Electrical tape and Rosary Beads......you just never know.
Dan McGrath is offline   Reply With Quote
Old 11-12-2012, 09:53 AM   #5 (permalink)
Main Motorcycle: 2011 Street Triple R
williamr's Avatar
Leatherman Wave and a bit kit (screwdrivers, torx and alan bits) on my belt. Tyre plug kit. Bits of wire, Scotchlock connectors and fuses - most roadside problems tend to be electrical. Clip link as a get you home for a broken chain (never broke one). A solderless nipple for throttle and clutch cables (never used) A small 1/4 drive socket set and set of small open ended spanners. Mole grips. Insulating tape. Spare headlight bulb. Ty-wraps. Pair of surgical gloves. That all goes easily under the seat.
Cell 'phone and wallet with credit card in my jacket pocket.
On a longer trip (more than 200 miles from home and/or overnight) I'll usually have my laptop in my gear (with TuneECU cable and service manual PDF), WD40 and duct tape. That usually drops in the top box. Never needed the laptop and as I have the service manual on my Kindle I carry it mainly because I need it for work. Never go anywhere without the Kindle (nothing to do with the bike), so I may as well put manuals and documents I might need on to it.
Small Maglite type torch lives permanently in the top box.
For the record, I did break a chain in 1970, a clutch cable in 1979, and I had a puncture in 1982 and another 3 days after getting my Street Triple R brand new last March.
Rob
williamr is offline   Reply With Quote
Old 12-25-2012, 08:10 PM   #6 (permalink)
Main Motorcycle: Triumph Bonneville SE
Other Motorcycle: Vespa 250 GTV
For longer trips, in addition to a tyre plug kit, I take a CyclePump. Not a toy, they are quality 12 volt air pumps.
Nevada Bonny is offline   Reply With Quote
Old 01-11-2013, 02:04 PM   #7 (permalink)
Main Motorcycle: 07 Bonnie
BonnieSquid's Avatar
Duct tape is always handy, I also have a small screwdriver that is flat and phillips, a gerber multitool, and a couple sockets. The fuse idea is a good one, I might have to start doing that too. I thought about trying to make one of those little leather backs on the front forks for long trips so it's not weighing down my backpack.
There are very few personal problems that cannot be solved through a suitable application of high explosives
BonnieSquid is offline   Reply With Quote
Old 01-19-2013, 03:28 PM   #8 (permalink)
Duluth trading has some amazing tape that can be used to fix almost anything, it is small and extremely handy. A small amount of safety wire with or without the pliers can be a life saver as well.
AshlandTriumph is offline   Reply With Quote
Old 01-19-2013, 04:22 PM   #9 (permalink)
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
Re: What's in your motorcycle tool bag?
All the above except I use a CO2 pump, the reason being it gives a very powerful blast which can seat beads on the rim, I carry a dozen capsules two do several tyres if needed.
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is online now   Reply With Quote
Old 01-20-2013, 01:58 AM   #10 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
Just curious; under what circumstances would seating a bead be something you'd do on the side of the road?
Cheers,
-Kit
Carb adjustment tool - D shaped tool Gary_spain Twins Technical Talk 0 03-25-2012 05:53 AM
Favourite/Most useful Tool in your Tool Chest DEcosse Speed Triple Forum 21 11-27-2011 11:54 PM
Motion Pro Motorcycle Hex Axle Tool RidersDiscount Riders Discount 0 07-19-2010 01:01 PM
MOTORCYCLE MADNESS- ATLANTA'S Summer Motorcycle Show gams Rides & Events 3 07-23-2009 12:19 PM
Tool Talk: Spark Gap Tool Preference? 00wabbit Maintenance & Workshop Talk 6 01-15-2005 02:02 PM
