Oil and Storage - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 08-06-2012, 10:55 PM   #1 (permalink)
Main Motorcycle: 09 Bonneville SE
Oil and Storage
I have a newbie question that is frustrating me because I just spent 70+ dollars for a gallon of top grade synthetic 15W-50 for my baby!
I have to put the bike away early this year because I will not be here to take her out for the final few summer months, and I had planned to do an oil change just before covering her up. Weather permitting, I will be bringing her back out in about 7-8 months.
Why does Triumph recommend changing oil if the bike has been in storage for 4 months? Do they also own oilfields, or is there a real reason for this?
Plantbi is offline   Reply With Quote
Old 08-06-2012, 11:38 PM   #2 (permalink)
Main Motorcycle: America
Libertine's Avatar
I believe it's because when a bike is stored for a long time, climate change can cause and create condensation in the crank case, contaminating the oil. Someone correct me if I'm wrong, but I think I remember reading a thread on that before.
Don't let the details of precision become obscured by the monotony of routine. JW
Libertine is offline   Reply With Quote
Old 08-07-2012, 12:06 AM   #3 (permalink)
Immoderate Moderator
Legend
Main Motorcycle: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: 2000 Sprint ST
That sounds like a job for a gallon of cheap 10W-40! No reason to waste the good stuff on storage.
Cheers,
-Kit
Old 08-07-2012, 12:31 PM   #4 (permalink)
Main Motorcycle: Triumph
leave the old oil in til you want to ride the bike again.
rupert fridge is offline   Reply With Quote
Old 08-15-2012, 01:10 PM   #5 (permalink)
Main Motorcycle: 2012 base bonneville
Extra Motorcycle: 2006 XL1200L
i remember reading that oils in storage in the container or your ride deteriorates, especially dino oils, most synthetics are not REAL! just highly refined group III oils, thank scumbag casrtol for that!
rodhotter is offline   Reply With Quote
Old 08-16-2012, 12:30 PM   #6 (permalink)
Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
oldndumb's Avatar
Other Motorcycle: 05SV1K, 2012 Ducati M1100
You can also add the _______ judge who adjudicated the case to the scumbag list.
Oldndumb
Caveat lector
Old 08-17-2012, 03:29 PM   #7 (permalink)
Main Motorcycle: Sprint ST 955i
Black Dog's Avatar
Other Motorcycle: Yamaha XT600E
Used engine oil contains a lot of contaminants. New oil doesn't really degrade just sitting in an engine. Therefore my advice would be to change the oil just before you put her to bed, and run it up to temperature for a few minutes to drive off any condensation. When you want to ride again, a quick level check and off you go.
If you live in a damp/cold climate, it is also a good idea to remove the plugs and put about 10cc of oil in each cylinder. Turn the engine over a few times (use kickstart or turn back wheel in high gear) to distribute the oil around the bore, put the plugs back in and leave it. If condensation really bothers you, you could also stuff cotton rags in the ends of the exhausts. Battery out and on an Optimate for the duration, or charge monthly with a normal charger. Weight off the wheels if possible. If not, move the bike every so often so the tyres don't develop a flat spot.
If you put a cover over it, make sure it is a breathable one. An old cotton bedsheet would be ideal. Condensation under a non-breathable cover can cause a lot of rust over time. In the UK (and maybe Canada is similar) I would also spray all exposed metal parts (not brake discs, of course) with WD-40 or similar.
2002 Sprint ST 955i (now sold)
2004 BMW F650GS
1995 Yamaha XT600E
www.goingfastgettingnowhere.blogspot.com
Black Dog is offline   Reply With Quote
Old 08-17-2012, 07:34 PM   #8 (permalink)
Legend
KitNYC's Avatar
Thanks, BD. That's about what I would've posted if I'd had the time.
Cheers,
-Kit
Old 08-21-2012, 11:00 AM   #9 (permalink)
Thanks for all the information,
I now plan to do the cheapie oil change option before I put her away, then unleash the good stuff next spring (or summer).
Old 08-22-2012, 10:45 AM   #10 (permalink)
Main Motorcycle: 955i
repsolracer22's Avatar
i think oil can become acidic after a period of time due to change in temp & condensation, etc etc .... yeah dont store it with the good stuff.
repsolracer22 is offline   Reply With Quote
Storage c-m Sprint Forum 7 05-20-2011 09:52 AM
air box with storage Paddyboy30 Twins Technical Talk 4 07-30-2008 06:29 AM
storage yakoo11 Triumph SuperSports 1 05-20-2008 09:13 PM
Storage? wingedwraith Speed Triple Forum 4 08-20-2007 05:56 PM
Storage eljohn3 Twins Technical Talk 2 06-23-2006 04:58 PM
