Bel Ray Super Clean Question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-03-2005, 08:50 PM   #1 (permalink)
So i just applied this stuff after cleaning off the sticky pj blue label stuff i had on there. How often should I reapply it and do you just keep applying it each time, or do you need to clean the chain each time prior to applying?
Thanks!
-dennis
2009 Bonneville
d2mini is offline   Reply With Quote
Old 09-03-2005, 10:04 PM   #2 (permalink)
Main Motorcycle: '03 T-100 & '08Tiger1050
I am currently cleaning my chain every other time I apply Bel Ray Super Clean. I could probably go longer between cleanings, now--my dirt road was "chipped and sealed" this summer so my chain stays cleaner, longer. :-D
Larry
Larry
Old 09-03-2005, 10:52 PM   #3 (permalink)
Main Motorcycle: 04 Bonnie black
Dennis,8000+ miles with BelRay.Have never cleaned the chain.Re-apply the super-clean whenever I think of it,maybe 7-800 miles. When the road crud builds up on the chain,the lube dries and falls off,taking the crud with it. Chain and sprockets look new and have needed adjustment twice,both before the 2k mark. Steve
a cleaning / polishing question for the really clean types out there TB-T100 Twins Technical Talk 12 07-24-2007 01:14 AM
Bel Ray Super Clean vs. Sperm Oil KAH24 Speed Triple Forum 14 07-18-2007 07:58 AM
Super dumb question... melam Speed Triple Forum 5 10-26-2006 08:17 PM
Bel Ray EXR Oil Silverado57 Twins Talk 0 05-13-2006 07:39 PM
Anybody ever use Bel Ray molyphos chain lube? kid911 Twins Talk 1 12-29-2005 06:24 PM
