Removing rust on chrome - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 12-24-2010, 12:18 PM Thread Starter
Main Motorcycle: '73 TR7RV (Tiger) 750
Other Motorcycle: Kawasaki ZZR1200
Hi all,
Rebuilding a '73 Tiger 750. I have spots of rust on chrome, for example on the "inside of the wheels" as well as under the fenders. the rust spots/speckles come off easy, but there are some more difficult spots. The rust is not very bad, and no where has it eaten through the metal. I've tried the Aluminum foil and coke - it worked ok, but not on real tough spots. Also steel wool with a metal polish, also decent results, but still there are some areas that its diffulct to remove. I was thinking of a soft wire brush to attach to a drill, but I know some of the chrome wil come off. Any input appreciated.
marsza is offline
post #2 of 17 (permalink) Old 12-24-2010, 03:16 PM
Immoderate Moderator
Main Motorcycle: Black '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Blue '04 Sprint RS
Extra Motorcycle: Tedium 850
Naval jelly may help. It has the same phosphoric acid the Coke does, but at the proper strength for rust removal. I usually use it with a Scotch-Brite pad or an old toothbrush.
Cheers,
-Kit
KitNYC is offline
post #3 of 17 (permalink) Old 12-25-2010, 04:44 AM
Main Motorcycle: 2006 Thruxton Caspian Blu
ocguyocguy's Avatar
Other Motorcycle: H.D. and Honda
Extra Motorcycle: MX, off road, Enduro
White vinegar...how do it know?
I don't know if this would work for you BUT
I have had good results soaking rusty parts in white vinegar
like the kind you buy at the market for cheap...
When I have SOAKED parts over night it BLASTS only the rust off
How do it know to get ONLY the rust...
ocguyocguy is offline
post #4 of 17 (permalink) Old 12-25-2010, 10:13 AM
Main Motorcycle: 2008 Triumph Rocket III
Shadowofleaves's Avatar
Other Motorcycle: 2014 Triumph America LT
Extra Motorcycle: 2001 Triumph Thunderbird
Birchwood Casey makes a chemical called "blue and rust remover" for firearms that you should be able to find at Walmart or your local gun store. I've used it to remove surface rust from guns before refinishing them. You might try that and follow up with a coat of oil or wax to seal the metal to prevent the rust from coming back.
Shadowofleaves is online now
post #5 of 17 (permalink) Old 12-25-2010, 10:30 AM Thread Starter
thanks all. I read about the Naval Jally - but when I read the container it said not for use on chrome.... Wonder if its the same for the Blue and Rust remover...
I'll try the vinegar in the interim.
marsza is offline
post #6 of 17 (permalink) Old 12-25-2010, 12:05 PM
Main Motorcycle: 2013 Triumph T100
Kem770's Avatar
Location: Nestled in the heart of America and the Loess Hill
Other Motorcycle: 1978 Yamaha DT400
Extra Motorcycle: 2003 Honda Metropolitan
I found this information.
Kem
http://www.ehow.com/how_2147060_remo...st-chrome.html
I'm no gynecologist, but I'll take a look.
Kem770 is offline
post #7 of 17 (permalink) Old 12-25-2010, 01:03 PM
Main Motorcycle: 2015 Rocket III Touring
Rocket XIII's Avatar
Other Motorcycle: 100th Anniversary T100
Extra Motorcycle: 2015 Tiger Explorer ABS
Happich Simichrome is the classical polish/preservative for chrome products. It dates back to the times when Turner's Twins were Kings.
I always keep a tube on the shelf.
Now as for removing rust from chrome .... if the simichrome doesn't get it, then that means the chrome plating has failed, which is the most likely scenario if rust is present anyway.
So a trip to the rechromer may be necessary for the diseased parts if you really want them to be right.
Rocket XIII is offline
post #8 of 17 (permalink) Old 12-25-2010, 05:30 PM
Main Motorcycle: Tiger 955i
Belton's Avatar
I use autosol, http://www.autosol.com/
Belton is offline
post #9 of 17 (permalink) Old 12-26-2010, 01:30 AM
KitNYC's Avatar
Originally Posted by Kem770 View Post
Note that eHow also has an article titled "How to Remove Rust From Chrome Motorcycle Tires." Never trust anything you read on that site unless you can verify it elsewhere; it's kinda like going down to the laundromat and asking the weird dude who hangs out there how to do something.
Cheers,
-Kit
KitNYC is offline
post #10 of 17 (permalink) Old 12-26-2010, 01:17 PM
Main Motorcycle: '02 CE Speedtona 955i
BombFactory's Avatar
Aside from chemicals, or along with them, use superfine steel wool to polish the chrome. It will clean things up well and let you see if you have pitting, spiderwebbing, or flaking. It won't scratch the chrome.
I have no spur
To prick the sides of my intent, but only
Vaulting ambition, which o'erleaps itself
And falls on the other. -Macbeth knew
I.VII
BombFactory is offline
removing chrome? damonallen Classic, Vintage & Veteran 1 09-25-2010 05:32 PM
Rust and Chrome, Shadows and Dust Major Kong Maintenance & Workshop Talk 6 06-15-2009 03:08 AM
Removing chrome from pipes Granitsky Air Cooled Twins Technical Talk 12 12-11-2006 03:05 AM
Removing topical rust from chrome evilfunkgenius Air Cooled Twins Talk 15 07-31-2005 02:49 AM
