| Maintenance & Workshop Talk The central area for general maintenance, trouble-shooting and modifications ------------
(Other technical forums on the site are model specific) |
02-09-2010, 03:47 PM
Minitwins Favourite Bike: Triumph Speed Four
Speed Four 02
I have a problem with my speed four, it was running fine yesterday but this morning I turned the key and got no indications on the dashboard (engine/oil lights, neutral light not even the speedometer). The alarm, headlights and break lights work fine, battery is OK but the ignition button is dead.
Any idea what might be the problem?
02-09-2010, 03:55 PM
plenipotentiary
Site Supporter Supernova Favourite Bike: Speed Triple
Posts: 22,373 Other Motorcycle: CBR1100XX Extra Motorcycle: Piaggio MP3
This is going to sound silly, but it's happened to me and others; but have you checked the run/stop button? Sometimes it gets bumped and can be frustrating. The other thing to look for is the kickstand. Is it all the way up? Sometimes the ignition interrupt switch on the kickstand can get dirty and not allow the bike to start. Just my 2 cents worth. Good luck!
I like to reminisce with people I don't know.
02-09-2010, 03:57 PM
no, its none of the 2.
I checked the engine stop switch and the bike normaly starts if you have the stand lowered, it only kills the engine if you select a gear. Engine should start and run normaly with the stand down as long as you have neutral selected.
Thanks anyway
02-09-2010, 05:13 PM
Immoderate Moderator
Site Supporter SOTP Vintage Series Favourite Bike: '04 Sprint RS
Posts: 7,912 Other Motorcycle: Dead '96 Trident in NYC Extra Motorcycle: '77/'82 Suzuki GS550/650
Is anything stressing the wiring coming out of the righthand switchgear? The dash being off like that is usually an indication that the kill switch circuit has been activated, even if the switch itself has not.
Cheers,
-Kit
02-09-2010, 05:17 PM
haven't checked that. might be the case. I ll have a look tomo morning
02-09-2010, 05:23 PM
Site Supporter Moto Grand Prix Favourite Bike: '04 D955i
Posts: 2,529 Other Motorcycle: '98 T595
promufa, The symptoms are just like the kill switch being activated...been there more than once.
Could the switch gear have become wet? Spray some WD40 into the housing.
Brad
02-09-2010, 05:26 PM
Yeah the bike got rained on last night. Will try with the WD40 and see how it goes.
Thanks!
02-09-2010, 11:32 PM
It happened to me again after my last post here! Had to wiggle the damned switchgear around to start my bike. That is a really dumb design; the wiring should exit from the bottom of the switchgear instead of the side, and it doesn't make me any happier that I have to move the brake lever to get clearance for the wiring!
Cheers,
-Kit
02-10-2010, 04:31 PM
Problem solved !
One of the fuses had oxidized connectors. Wiped em clean with WD40 on a piece of cloth, reinserted and bike works perfectly fine.
Thanks all for the suggestions
02-10-2010, 04:37 PM
plenipotentiary
Yippee! Nice work!
