Sporadic MIL and Low Fuel Lights on 955i Tiger - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGearHonda Powersports
Old 11-10-2009, 10:52 AM   #1 (permalink)
Hello All,
I have been getting an occasional MIL and Low Fuel light (accompanied by a stall) on my new (to me) 2001 Tiger 955i. When it happens, the bike begins to cut-out and both lights (MIL and low fuel) illuminate, but within 1-2 seconds it clears and the bike runs fine. Granted, this has only happened a few times and I can go several hundred miles before it happens again, but it is troubling to me nevertheless. This appears to be an electrical gremlin and I was hoping that someone has experienced this before. Unfortunately, the ECM hasn't stored any error codes to help locate the fault. I read an old thread in which a similar problem was caused by a loose + battery cable. My + cable appears fine, so if anyone has any ideas, I would appreciate hearing them.
Here is what I have done so far...
Checked all fuse connections (look good)
Checked main relay connections (look good)
Checked + and - battery cables (they appear to be good)
Disconnected and reconnected the ECM plugs (problem still occurs)
In the meantime, I plan to disassemble the engine kill switch and examine the ignition switch. I will update this thread if I discover anything.
I have looked through the wiring diagram in the manual and am going to start tracing wires. Does anyone know where the alarm connector is on the Tiger? I cannot locate it. It appears that both the MIL and low fuel circuit share a common pathway through the alarm circuit (which I presume is a bypass since my bike doesn't have an alarm), so I would like to check these connections.
Thanks in advance.
CharlestonRider
CharlestonRider is offline   Reply With Quote
Old 11-10-2009, 03:24 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
It sounds like it could be a problem with the fuel tank sending unit. I had one in my Daytona 955i that bugged out. It would illuminate the low fuel light, and eventually tripped the MIL for a sensor to ground error. The engine never stalled, however, and the problem was solved after I replaced the sending unit.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 11-10-2009, 04:19 PM   #3 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
Fuel sender was my first thought as well, but that would only explain the lights, not the stall.
CharlestonRider, did you check the battery cables visually, or verify that they were tight by snugging them down? You want to make sure they're tight with a screwdriver, not just your eyes. (Not saying you didn't, just want to make sure.)
The ignition switch would be my next target after that. I don't know the Tigers, but some of the Hinckley bikes are prone to issues with the wiring harness at the headstock. It's worth looking for exposed or broken wires there.
If it's worth checking the kill switch, it's probably worth checking the clutch and sidestand switches as well...
No idea where your alarm connector is, try asking in the Tiger forum. (Do keep us in the loop here, though, please.)
Cheers, HTH,
-Kit
KitNYC is online now   Reply With Quote
Old 11-10-2009, 08:36 PM   #4 (permalink)
I have located the Alarm Bypass
BombFactory and KitNYC,
Thanks for your helpful suggestions. I really appreciate your thoughts.
As for the alarm bypass...It is located under the tailsection (in front of the taillight). I wasn't paying close attention when I separated the connector, but I think the bypass connector was a little loose. So, I have cleaned it out and reinstalled it. Tomorrow I will start the bike and disconnect the bypass to see if I can mimic the symptoms I have been experiencing.
I will keep you posted.
CharlestonRider
Old 05-25-2011, 12:07 PM   #5 (permalink)
An update on this issue...
Sorry it has taken so long to update this (I have since sold the Tiger, so I stopped checking on the TriumphRat site). Anyway, I figured out the problem regarding the sporadic MIL light. It was one of the relays under the seat (the main relay, if I remember correctly). The contacts were dirty and the relay was not seated completely. Once I cleaned the contacts and re-seated the relay...No more troubles. Hope this helps someone.
Old 05-25-2011, 02:48 PM   #6 (permalink)
KitNYC's Avatar
Thanks for the followup!
Cheers,
-Kit
Triumph top box for Trophy/955i Tiger/955i Sprint Jonny955 Trophy 1 10-28-2009 03:17 PM
Tiger 955i intermittent fuel guage fault Jacqueslemac Tiger Workshop (archive) 5 11-20-2008 05:46 PM
LED instrument lights in 955i mikeg15 Tiger Mods & Bolt-Ons (archive) 0 03-10-2008 12:40 PM
Quick question re 955i lights. Nickwiz Daytona Deliberations 3 09-07-2006 05:20 AM
fuel guage, fuel and rear lights boocat Tiger Workshop (archive) 2 02-27-2006 07:26 PM
