Thanks for the reply, the weather is poo up here right now and I have a wedding to go to so it looks like this is prob gonna have to wait until Sunday.
http://www.bikebandit.com/houseofmot...t-1975/o/m9224
In that link I am looking at the clutch and left crankcase schematics. I was told that the clutch works very similar to the Triumph ones in the 60s.
Some things I can answer you though..
-I can shift through the gears when the clutch is actuated
-the lever becomes limp when I am in neutral and rolling
-it does not pop immediately , just within 10 feet or so of going backwards, I have not had it go limp while going forwards, everything seems to be good until I roll it back to get it out of the garage
-One of the problems is that I cant remove the cover because the cover has the adjuster in it, so it separates it from the pushrod as seen in the schematic. I have removed, honed and lubed up the rod.
-cable is good.
-I have heard that adjusting these clutch cables are a pain.
When I get back to it, I am going to clean it up and make sure all the pieces are there (like the ball bearing that pushes on the rod) and readjust the cable in a manner suggested by someone else. They dont seem to thing its as much a mechanical failure as it is a adjustment problem. Until now its just a pain in the butt because I am planning on selling the bike, its in perfect condition.
Thanks for now!
